Results 1 to 6 of 6
Thread: guna change my front wheels hubs, any advice?
    slepar's Avatar
    slepar is offline omg duz it like...dose??
    vn ss
    Mar 2007
    Default guna change my front wheels hubs, any advice?
    ok guys my front right wheel bearing/hub is buggerd it makes a terrible bearing/rotation noise after 80ks and im sick of it im guna change it hopefully tomoro if i get time, is there any special tools ill need any hints to make this go smoothly?
    ive changed one before but it was ages ago and i cant remember how i done it/ what tools i used
    all help much appreciated
    cheers ricky
    doin skids for the kids and doughnuts for the grown ups
    strgas's Avatar
    strgas is offline GRA = REAL HP
    Oct 2009
    no special tools require just a pair of side cutters for the split pin a hammer and punch to remove the old bearing cone a jack a wheel brace and a 19 mm spanner or socket pliers to remove grease cap thats about it ?
    VS 5L UTE - VR V6 5SPD
    Oct 2008
    bayswater
    Quote Originally Posted by strgas View Post
    yer maybe if u doing vl hubs
    vr/vs have a sealed hub that needs to be purchased and there ova 100 bucks each and u will need a 10mm hex socket there are 3 bolts holding it on
    example
    http://cgi.ebay.com.au/Holden-Commod...item414cd79042
    dirt drifter's Avatar
    dirt drifter is offline white trash hillbillie
    VS 5L M5 VS 6L M6
    Apr 2009
    massive hole in the ground
    i did mine not long ago and got genuine ones from holden (skf brand) they cost around 250-300 bucks each, i wasn't going to trust the cheapo chinese ones off ebay
    a decent size breaker bar and some loctite would be handy for the hex bolts holding the hub on
    Quote Originally Posted by UFO View Post
    worked v8 + supercharger + dogbox = panty moistening equipment.
    4 banger turbos with bov's will just cry when they hear it, because they can never have it.
    Quote Originally Posted by GRPABT1 View Post
    Avoid cluey police
    slepar's Avatar
    vn ss
    Mar 2007
    thanks guys, does anyone know what size the hex key is as ill have to go buy one i don t have any?
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Just went up the shed and checked the one I used - it says 3/8. I used a piece of pipe about 500mm long to add leverage when removing and installing the hex bolts. Turn the wheel from one side to the other to make removal/installation easy.
  1. VY Wheels - Stuck on the Hubs
    By Sean880 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 05-09-2009, 10:07 PM
  2. New Hubs - Speed reading 20km/h Over rear wheels
    By Dangerous Dave in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-04-2009, 10:16 PM
  3. Front wheel hubs..
    By dylanfh in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-01-2009, 08:57 AM
  4. F.S IN VIC vt hubs and vn front brakes
    By wildss in forum Parts And Other Items For Sale
    Last Post: 29-10-2008, 05:10 PM
  5. Vt Front Hubs
    By pistonbroke in forum General Discussion
    Last Post: 29-01-2006, 10:29 AM
