Results 1 to 10 of 10
Thread: Holden VS overheating problems etc.
    VS Berlina
    Jan 2009
    NSW
    Default Holden VS overheating problems etc.
    Ayeeeeee
    I was wondering, my holden VS seems to be overheating. It will sit on a bit over halfway and then when stopped go up to 3/4 then when driving drop back down to halfway'ish but what worries me more is when I stop and turn off the car the overflow is bubbling because air is being pushed out of the hose from radiator to overflow and there is a lot of pressure in that hose and none in the one from the radiator to the block (main one) also when I bleed the top screw on top of like the block all coolant comes out in like a stream.
    Help plz
    VS Berlina S2
    Feb 2010
    Easiest and cheapest is the thermostat. Mine was running like that back in January and I took a punt on the thermostat. Immediate success. Not saying that's your problem but for 10 bucks it's worth replacing.
    87 VL Berlina
    Jul 2009
    i have the same prob
    i have replaced the thermalstat, both sender and sensor...next bet is the water pump
    VS Berlina
    Jan 2009
    NSW
    I replaced the thermostat and my water pump is quite new so yeah, in a pickle :P
    BoNeZ-01's Avatar
    BoNeZ-01 is offline "..of mice and men.."
    '95 Cino(daily driver), Project: VS.
    Mar 2010
    Central West, NSW(middle of nowhere).
    Same with my VS, which threw me when I first got it, after being so used to my VR rarely getting above 1/4 temp?
    I read somewhere in here about changing the coolant sensor to one with a white connector, instead of black, cause white turns the fan on sooner, at a cooler temp apparently?
    If your sure your fan is working(mine don't turn on till just over 1/2 temp), then maybe try giving the a radiator good flush, just in case it may be a little blocked?
    On the 7th day, God created Holden, then on the 8th day, God created Ford, to keep idiots out of Holden's.
    Quote Originally Posted by destiny View Post
    so im gonna need a supercharger? fck that ruined my dreams, oh well, it will b easyier to get a turbo then i dont have to pay for the boost..
    wtf? im not stupid, theres no such thing as a tyre valve
    vs commodore
    Oct 2009
    Tamworth NSW
    Go and get the cooling system pressure tested and get the engine compression tested as well.This is the only way to make sure everything is as it should be with the cooling system.These tests are cheap to get done and will tell you if theres any gaskets leaking or blown (usually accompanied by cooling system problems).These engines are known for blowing inlet manifold gaskets or sometimes (but to a lesser degree) a head gasket.
    vx s pack II
    Jan 2010
    aLKIDA
    Does the fan come on when when the temp is on half way?
    You need to bleed the system. Do this when the motor is cold. Turn the car on and and the heater on and bleed from the bleeder screw.
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    blocked radiator????
    BoNeZ-01's Avatar
    Mar 2010
    Quote Originally Posted by RX25SE View Post
    As in, full of shite, rust and scale, restricting it's flow..
    RX25SE's Avatar
    vsII acclaim wagon
    Jan 2009
    Quote Originally Posted by BoNeZ-01 View Post
    Yup.
    Should be green and clean inside.
  1. Help. Vt Holden Commodore problems.
    By MechanicFreak in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-02-2010, 01:01 PM
  2. Overheating Problems
    By The_HSV_Chick in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-09-2009, 09:57 PM
  3. HELP VS Comodore Overheating Problems
    By VS_commodore09 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-03-2009, 05:36 PM
  4. holden VN problems
    By bman88 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-02-2009, 07:17 PM
  5. Holden Nova problems
    By one_and_only2004 in forum The Pub
    Last Post: 25-11-2008, 09:33 PM
