Results 1 to 5 of 5
Thread: V6 VR manifolds
    jono1492 is offline DTD
    VE omega
    Dec 2009
    Forrestfield, Perth
    Default V6 VR manifolds
    Hey guys, I'm looking to replace my exhaust manifolds as one of them has a leak. I went to a wreckers to get a set and they told me I need to find a serial/product code for the ones I already have. I know that I'm just replacing my leaking manifolds with ones that are just as old, but I don't have the money for extractors at the moment
    So, a few questions;
    1. Where can I find the serial/product code on my manifolds?
    2. Is there a company that makes new factory replacement manifolds?
    3. What are they like to install?
    4. Is there anything I can do to make older manifolds last just a little bit longer(eg. a paint)?
    5. Is painting manifolds practical and safe?
    Any help would be hugely appreciated,
    Jono
    Mar 2009
    VE omega
    Dec 2009
    Forrestfield, Perth
    Mar 2008
    has the manifold actually got a hole in it or is it just leaking from your manifold gasket
    painting them is fine if you want to, wont stop it leaking though
    just make sure you buy hi temp paint for exhaust manifolds and when you first start it do it in an open area as it will smoke like a sob for a while and stink
    i recently sprayed my new exhaust system, i would let it run warm up a bit till it started smoking turn it off , let it cool a bit then repeat the process a few times
    i think painting older rusty manifolds wont have any effect other than looks, but painting a new set should hopefully keep the rust at bay for a while
    VE omega
    Dec 2009
    Forrestfield, Perth
    Quote Originally Posted by deanos70 View Post
    Yeah, I found the crack today, so a replacement is in order, I understand painting wont do much in regards to fixing the leak, but i figure if I replace them with factory ones, they could do with some paint
  1. [Ecotec] v6 manifolds
    By p_schrapel in forum V6 Development And Modification
    Last Post: 01-05-2009, 12:14 AM
  2. same manifolds?
    By bob308vk in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 07-08-2008, 05:20 PM
  3. vn - vr v6 exhust manifolds???
    By VR 3.8 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-03-2007, 10:49 PM
  4. Exhaust Manifolds
    By markovr in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-01-2004, 09:05 AM
