Results 1 to 14 of 14
Thread: VS wont start. Fuel Pump?
    VS ute 3.8
    Feb 2008
    Default VS wont start. Fuel Pump?
    My 98 VS ute died on me today. It wont fire up, just turns over. I cant here the fuel pump when i turn on the key. My mate took the fuel hose off the filter, and no fuel, with the key turned on.
    I want to get a new fuel pump and change it over. I take it the fuel pump is on the top of the tank?, so i have to remove my ute liner, and the pannel covering the fuel tank.
    Can anyone give me any further intructions, or tips on how to change the fuel pump?
    Thanks
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Double check it is the fuel pump that's gone. Check the relay....also hotwire the pump to see if it runs....or thump under the tank to give the pump a jolt - this usually starts them up again.
    Check the immobiliser light below the wireless goes out when you switch the reds on.
    Mar 2009
    fuel pump is inside the tank, you have to take the tank out of the tub to replace it on a ute, i did a ute one a month or so ago, 2 hours should see it done. Pretty easy to do but tank defo has to come out on a ute.
    VS ute 3.8
    Feb 2008
    Quote Originally Posted by hako View Post
    Done all that. Relay is good, (swaped em around)
    the immobiliser light goes out when i crank it over
    I got a new pump today. I will have a go on the weekend. I have to take the ute liner out.
    Then i was told to check if i have power going to the fuel pump. If i have, then it should be faulty pump.
    If not, well, it's a 57KM tow into town to have it fixed.
    VS ute 3.8
    Feb 2008
    Quote Originally Posted by westbad View Post
    Why does the tank have to come out of the bay? I thought fuel pump access was from the top of the tank? man, i have 50 litres of fuel in it, how do i get that out?
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Quote Originally Posted by wiseman View Post
    Just a few points - the immobiliser light should go out when you turn the reds on....not only when it's cranking.
    You can syphon the fuel out either via the filler or the pump outlet. If you have access to an electric fuel pump like an old SU, you could use that to speed things up.
    Westbad knows his stuff so if he says the tank must come out, then it must come out.
    Check the EFI relay
    Violet is the +12v wire at the pump and black is the -12v wire....so if you apply +12v to the violet wire the pump should spin if OK.
    Good Luck.
    VS ute 3.8
    Feb 2008
    Check the EFI relay
    Good Luck.
    Thanks Hako
    Yes, i should have said, the immobiliser light goes out, when the ignition is on,(dash lights on)
    I will check the EFI relay, (can i swap it with another one?)
    Rather than to 'hotwire' the pump, Can i test if there is power to the pump, by connecting a test lamp to the +12v Violet, and earth out the test light, and have someone turn on the key, and if the test lamp lights up, then there is power. I understand it will only light up for a few seconds, when the key is first turned on, then comes on again when cranking begins.
    PS. this ute is really starting to piss me off, when it hit 200,000KM, things have gone down hill since then. I had starting problems.
    So, NEW DFI unit, (old one blew, lost spark on 2 cyl), second hand coil pack, New spark plug leads, and new NGK Plugs. I also have a new crank angle sensor, to be fiited.
    Now this SH#T !
    VS ute 3.8
    Feb 2008
    Default fuel pump
    After searching the forum, and reading about fuel pumps, i now know why the tank has to come out, (dah) cause the access for the fuel pump is on the side of the tank.
    So, after reading so many posts about what a prick of a job it is, im having it towed to town on Monday, and pay someone eles to do it.
    Im joining the NRMA tomorrow, so i should get a free tow into town in a few days
    Joining Roadside Service, will be cheaper than paying for a one off tow.
    Im nearly 60KM from Town.
    Mar 2009
    Its an easy job to do mate, if your handy with your tools you will have no problems.
    yep access to the fuel pump is on the side of the tank nearest to the cab, all you have to do is remove the inspection cover in the tub and you will see the tank, remove the filler neck, undo the fuel lines, lable them so you know where they go, one will pump fuel to the engine and the 2nd is a return line, important you dont get them the wrong way round.
    4 bolts hold the tank in place undo them and lift the tank out.
    Once the tank is out undo the small bolts that hold the pump in the tank then you have to twist the pump around on its self to get it out of the swirl pot and out of the tank, be carefull not to dislodge the return line thats connected to the bottom of the pump and in to the swirl pot (or your car will die when cornering under 1/4 of a tank) you get the return line off the bottom of the pump once out of the tank by inserting 2 small allen keys or small metal rods etc in to the little holes in the top of the black thing that connects it to the pump, once you push 2 allen keys in to it the return line will simply slide off. No need to cut it off and reconnect it.
    Hope that made sense!! Then repeat in reverse and your done.
    Its a pretty simple job mate, why pay someone else to do it
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Thanks Hako
    Now this SH#T !
    Your idea is better and simpler than mine!
    Re the ute starting to piss you off - remember that if you trade it in, you are just buying someone else's car that they sold because it was pissing them off too.
    And like Westbad says, the job is not rocket science and something you could easily do.
    Good Luck.
    VS ute 3.8
    Feb 2008
    Good Luck.
    Yeah thanks guys. Im better off to stick with what i got, and what i know, as you say, i would only be buying someone eles's problems. People never sell anything,'cause it's good'
    I'm up to about $700 so far, chasing a problem, that has caused my ute to run like a bag of sh#t for the last 6 months.
    I had it towed into town today, after it broke down and stopped 50KM from town, and it's at the shop now. Let the experts fix the faults in it, with there diagnostic gear.
    Thanks for your help, and i will post the outcome of all this, when i get the bill!
    VS ute 3.8
    Feb 2008
    VS commodore ute
    Mar 2010
    I tried to fit a new fuel pump in my vs ute today and had trouble getting the fuel pump and sender unit out of the tank. Ended up damaging one of the wires that wrap around the sender unit..i might just take the tank in and get someone to fix it
    VS ute 3.8
    Feb 2008
    Quote Originally Posted by simmo371 View Post
    Yeah mate, it cost me 2 & half hours labour, (plus the fuel pump), at the local mechanics. I dont have the patiance working on cars anymore. Much easier to pay someone eles to do it.
    That way, if they break it, then they have to fix it. After getting that job done, the cabin of my ute smelt strongly of fuel for a few days. I know they spilt lots, cause it went in with a full tank, and came out with 3 Quarters!
  1. VP Wagon wont start, Fuel pump?
    By sweefu in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-06-2009, 10:27 PM
  2. VR ran out of fuel, filled up now wont start
    By magnumv8 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-03-2008, 08:04 PM
  3. new fuel pump , wont go
    By stu75 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-08-2006, 09:08 PM
  4. VK - LPG - Wont start on fuel..
    By Shifty1 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 28-03-2006, 12:01 AM
  5. 3.3 efi duel fuel wont start
    By vkefi in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 07-06-2005, 12:58 AM
