Results 1 to 4 of 4
Thread: Steering Noise
    VS s pack ute
    Jan 2010
    Default Steering Noise
    Hey guys, when I turn the wheel full lock either way it makes this strange buzzing/hissing sound, is this normal, if not what could the problem be??
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    If it makes the noise only whilst actually turning the wheel it's probably a dry bush where the steering column goes thru the bulkhead - spray from the engine bay with WD40.
    However if it happens when you stop turning the wheel (not straight ahead) then I'd check the fluid level in the power steering reservoir as it may be low.
    Good Luck.
    VR Ute
    Nov 2009
    Toowoomba, QLD
    I would check your power steering hoses, one of mine busted off and it made a hissing sound when i went around corners so i would assume that this is the same
    VX S S2
    Dec 2007
    Laidley, QLD
    Quote Originally Posted by hako View Post
    Good Luck.
    um if you have the wheel turned/full lock, but stopped, the noise wont happen as the noise will only happen as you turn the wheel(whether you are stopped or moving) i suggest you check the power steering fluid levels, top it up, if it still makes the noise, check all hoses ect for anything lose/disconnected, if none of that is the problem, have the power steering pump checked
    "Stop following me, i dont have any doughnuts!"
  1. vt - steering noise
    By SS 1998 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-10-2009, 05:48 PM
  2. VS Steering noise
    By randomhero11 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-11-2008, 01:59 PM
  3. power steering noise on vs
    By joshooaahh in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-05-2008, 09:13 AM
  4. steering noise
    By dandandaniel in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-01-2007, 04:24 PM
  5. Steering Noise
    By Kall911 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-08-2005, 06:48 PM
