Results 1 to 5 of 5
Thread: Why/how radiators split
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Default Why/how radiators split
    I recently noticed coolant weeping from a small split in the plastic side tank on my radiator - just below where the top rad hose enters. I've been watching for this as so many plastic/alum radiators seem to suffer from split tanks at my mileage (220,000km). The split occured just below where the top hose joins the tank and right where the fan housing bolts to the tank.....so it appears this split was caused by strain from the fan housing. Also noticed my coolant level was down slightly which has never happened before.
    So, ordered a new radiator from Ebay ($118 delivered) and installed it. Decided to rip the old one apart to see what the split looked like from the inside and also to see the condition of the tubes inside the radiator. When I pulled the tanks off I was very surprised to see absolutely no tubes blocked and only one or two pieces of foreign matter sitting in the tank. The radiator itself was still in perfect condition so really all it needed was a new plastic tank, however a new radiator is the easy option. The transmission oil cooler was interesting - I've included the cross section with the other pix.
    The message in this post is just to confirm that using the proper coolant does stop corrosion and preserves the aluminium core of the radiator.....too bad about the plastic tank! It also pays to keep a keen eye on coolant levels - if I hadn't noticed the coolant leak and the level dropping due to the split, the engine would have overheated and come to a sudden halt.
    I've attached photos of the split and the radiator tubes/core/oil cooler.
    Attached Thumbnails Attached Thumbnails Why/how radiators split-rad1.jpg   Why/how radiators split-rad2.jpg   Why/how radiators split-rad3.jpg   Why/how radiators split-rad4.jpg   Why/how radiators split-rad5.jpg
    vs commodore
    Oct 2009
    Tamworth NSW
    Interesting pictures.Something you dont see every day(unless you work at a radiator place).
    Good one Hako.
    wraith's Avatar
    wraith is offline Hand over the dog bikkies
    '95 VR Series II
    Sep 2008
    Demonicaland
    Quote Originally Posted by Brett_jjj View Post
    Good one Hako.
    Commodores are notorious for it. Who ever thought plastic on metal was a good idea was wrong.
    VS_Pete_1's Avatar
    VS_Pete_1 is offline Donating Member
    VE II SV6 MY12 Sportwagon
    Dec 2007
    Thanks Hako
    "Success is the ability to go from one failure to another with no loss of enthusiasm" Sir Winston Churchill.
    My VS II Berlina Wagon
    MY12 II SV6 Sportwagon
    VR exec 500k & still going
    Jun 2010
    Stawell
    Thanks for that as one added problem was leaking fluid from the Auto cooler, it doesnt leak water so now going to add a new cooler for the auto. To understand how it all works makes me feel safer in driving more than 30 kms'from Stawell, UR knowledge is unsurpassed manythabks for ur threads and info. cheers Russell
  1. Radiators
    By Static89 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-06-2009, 09:30 PM
  2. vl radiators
    By penguin0001 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 22-02-2009, 03:21 PM
  3. Pwr Radiators
    By RVN 355 in forum V8 Development and Modification
    Last Post: 11-02-2007, 08:04 PM
  4. Radiators?
    By LiLEd in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-03-2006, 04:42 PM
  5. VT/VX V6 radiators
    By smally in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-01-2006, 01:53 PM
