Results 1 to 12 of 12
Thread: VS Calais A/C
    VZ Berlina
    Jan 2009
    Maitland SA
    Default VS Calais A/C
    Have a 97 VS Calais, A/C works fine, gets down to the recommened temp. Can i make it any colder??? if i could make the thing make ice i would.
    Oh BTW it has climate control.
    Cheers.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Air conditioners can only cool down to a certain temperature always above zero. If they go too cold they build up ice on the evaporator. Winter is just around the corner.
    vs commodore
    Oct 2009
    Tamworth NSW
    The AC system when working fine should be able to cool down the interior of the car to around 10-15 degrees cooler than the ambient (outside) temperature.
    VZ Berlina
    Jan 2009
    Maitland SA
    ParkwayDrv's Avatar
    ParkwayDrv is offline ɹoʇɐɹǝpoɯ ǝsınɹɔ ɐʍ
    VZ SSZ
    Feb 2009
    your climate control goes down to 16.0 thats pretty frosty, unless your a snowman?
    Black, Red leather, 20" Pentagons, Red walls, Lowered, OTR, Mafless, 3.9s, Diff dumpers, 341rwhp...
    185i, Chasers, Flappers, Venetians, Sunvisor, Twin diff dumpers, 194rwhp...
    vs commodore
    Oct 2009
    Tamworth NSW
    If its 35-40 degrees outside,theres no way the AC system will cool down the inside to 16 degrees.
    moff_man's Avatar
    moff_man is offline operation HQ under way.
    95 VR II berlina wagon v6, 72 HQ ute 253
    Nov 2008
    if you press the blue cool button again you will get a C which means its just like normal a/c and will just keep getting cold,
    i have had some a/c systems down to 1.0 deg c at the vent on flow through on speed 2 @ 50km/h
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Quote Originally Posted by moff_man View Post
    That's pretty efficient....best I've managed was +3.0 deg C but that was stationary on speed 2.
    Holden VS Series II 1997 Ute - 5 Speed Manual
    Aug 2008
    Quote Originally Posted by hako View Post
    Its on
    BTW, does it really matter what temperature it is? As long as its cold?
    vs commodore
    Oct 2009
    Tamworth NSW
    When my system was regassed it was showing 4 degrees at the AC vent outlet on the AC guys digital thermometer.Id like mine to go colder on very hot days too,I asked the AC guy
    about it and he said the most they will cool down the whole car to is around 10-15 degrees below the ambient temp,as I mentioned before.
    moff_man's Avatar
    Nov 2008
    i gas a/c systems an i can get them low, but this is stright after a long vacc and fresh gas, we get dry hot days here which is better than humid days due to the hunidity in the air.
    i did my vl after a retro fit and used hi chill gas - which is crap mind you, and i got idling in the work shop below -1 deg c (yes thats a minus)
    EDIT: it all depends on the ambent temp of the day, average 35 deg day here i can get them cold but about 35 they tend to struggle, as well as humid days
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Going back a few years, but at Charleville they used to put the vacuum pump on the unit overnight to suck the very last vestige of air out...then at 8am attach the R12 and feed it in till the vac pump connection felt cold, then stop. They'd also adust the thermo down that sat in the evaporator....this was all OK till you went to the coast and high humidities when the evap could not dump enough condensed moisture before freezing. (believe it or not but Kmart sold R12 refill kits)
    Back a few years, Smiths put out an evaporative aircon using water to cool the car...OK in the west but dead loss on the coast.
  1. [NSW] VK Door trims Berlina & Calais + VL Calais
    By vkberlina in forum Parts And Other Items For Sale
    Last Post: 03-10-2009, 07:41 PM
  2. [SA] vx calais altezza monaro lights and vt/vx calais doors
    By callum_88 in forum Parts And Other Items For Sale
    Last Post: 24-04-2009, 01:33 PM
  3. Replies: 0
    Last Post: 26-12-2007, 11:34 AM
  4. Replies: 57
    Last Post: 12-10-2006, 08:47 AM
