Results 1 to 3 of 3
Thread: Dim Headlights
    Mar 2008
    Default Dim Headlights
    I have an electrical problem with my vs calais.
    The headlights are very dim but the highbeams appear fine so do all the other lights on the car.
    I replaced the bulbs and this did not fix it.
    I have also noticed the car has had problems starting latly, I will turn the igntion and nothing happens, all the dash lights up but there but nothing fires, I wait about 60 seconds and it starts without a problem, could this be an alternator or wire problem?
    Any suggestions would be greatly appreciated.
    Mar 2008
    mate i would be checking that the battery terminals are on tight or there is no corrossion on then
    check your earth cables are tight and not corroded where they mount to the body and the engine
    if that is all fine it could be a problem with your bcm
    vs commodore
    Oct 2009
    Tamworth NSW
    Check the relays under the bonnet(swap them around with the ones there that are the same).Check the alternator output as well.With the engine running it should be around 13 volts or a bit more.
  1. Exec/Acclaim Headlights --> SS Headlights for $80 ...
    By nEb. in forum VY Holden Commodore (2002 - 2004)
    Last Post: 23-06-2011, 11:06 PM
  2. VZ Headlights to Projector Headlights
    By harvs01 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 05-09-2009, 05:27 PM
  3. Headlights
    By powerclub in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 30-01-2007, 07:15 PM
  4. VR headlights
    By Aaronvrcalais in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-01-2007, 07:35 PM
  5. want a set of SS headlights?
    By Troy711 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 23-04-2006, 02:31 PM
