Results 1 to 6 of 6
Thread: VS Statesman Electric Window
    VS Caprice SII
    Mar 2007
    Northern Suburbs
    Default VS Statesman Electric Window
    Gday Guys. Just went to use my drivers side elctric window and heard a big pop as it was halfway down. upon further inspection one of the arms was bent inside the door trim. just wondering whether the whole mechanism inside can be replaced or not.
    VS Berlina 3.8
    Dec 2008
    Yes it can. You can pick up after market regulators off ebay or get them from a wrecker. You have to take the entire door trim off to get to it. This happened to me, but I just bent the arm back.
    These two threads should help you -
    Removing Front Door Trim on VN - VS
    How to install Power Windows
    VS Caprice SII
    Mar 2007
    Northern Suburbs
    VS Berlina 3.8
    Dec 2008
    Not really that hard, just time consuming. It's also better if you have two people. The hardest part is getting both arms of the regulator onto the window whilst the window sits in the bailey channels (I think that's what their called).
    Mar 2009
    you have to drill out the rivets that hold the mechanism in place, you can replace them with nuts and bolts will make things easier if you need to get it out again.
    VS Caprice SII
    Mar 2007
    Northern Suburbs
    how much do auto electrician or holdens charge to replace the regulator roughly
  1. Electric window help please
    By LiamVK in forum VL Holden Commodore (1986 - 1988)
    Last Post: 04-02-2010, 04:09 PM
  2. vs statesman electric window HELP
    By 5ltvsstaty in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-08-2009, 09:34 PM
  3. Electric window failure
    By aygee in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-08-2008, 11:18 PM
  4. F@#KED Electric Window
    By Tas_HSV in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-06-2008, 06:22 PM
