Results 1 to 11 of 11
Thread: trip computer
    Brendo169's Avatar
    Brendo169 is offline HSV Porn
    VS Senator
    Aug 2009
    WA
    Default trip computer
    just wondering what wires are needed for the trip computer to be working in a vs clubsport auto
    before today it has always worked... but through my aggressive fiddling with electrics in an attempt to install a speedo corrector i must have knocked a connection that controls the trip computer. just wondering what coloured wires i should be testing....according to the wiring diagram i have a yellow wire with black stripe controls the trip computer
    http://www.memcals.com/pdf/VSV8%20Ma...%20Diagram.pdf
    can some one else confirm this with me???
    where should i be looking for loose connections because i find it hard to believe that that one wire controls the odometer, fuel consumption gauge and trip computer all at once...
    any help would be greatly appreciated!
    thanks in advance
    Brendo169's Avatar
    VS Senator
    Aug 2009
    WA
    sorry forgot to mention that nothing shows up on the three little displays underneath the tacho and speedo....its just blank...but it worked before haha
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    The 4th plug probably is out.
    You need to test the orange/white to power up the ODO.
    and 3 Dangerous non ABS VN's
    holden vs
    Mar 2010
    have you got the small white plug, pluged in the buttom of the speedo if you take the fuse cover off and look up to where the speedo is you will see if its pluged in or not if its not im not relly sure ( iv put trip computers in all of my vn-vs iv owned and thats the only thing that had me stuffed when i did the frist 1)
    Brendo169's Avatar
    VS Senator
    Aug 2009
    WA
    yeah that plug is definately in!!
    88green VN
    what do you mean by the 4th plug
    how would i go about testing the orange white wire
    im sorry im quite new at auto electrics....i wish i new more!!!!
    thanks
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by Brendo169 View Post
    88green VN
    thanks
    The 4th plug - goes in the bottom of the cluster.
    The orange/white and black/white power the trip computer up. Find out if you have power at the main plug for the dash loom. If yes go to the 4th plug and see if you have power there.
    Brendo169's Avatar
    VS Senator
    Aug 2009
    WA
    your all going to laugh but it turned out to be a fuse
    when it first happened i checked the fuse and it was good
    then i discovered that the 4th plug was out...so i plugged it back in thinking that it would fix the problem
    haha then doing that must have blown the fuse!!!
    quite embarassing...glad it was something small!
    88GreenVN's Avatar
    Jun 2006
    OK we will have a little laugh - cheers
    Fekason is offline Fekason
    MY11 VE Series II SV6 Manual
    Mar 2005
    Penrith NSW
    Yes, I will laugh, but with you, not at you. I know the relief when a problem turns out easy to fix.
    Brendo169's Avatar
    VS Senator
    Aug 2009
    WA
    88GreenVN's Avatar
    Jun 2006
    funny because we have all done it before at some point
  1. Resetting your computer and trip computer special functions (VT - VX)
    By Darren in forum Holden Commodore How-To's
    Last Post: 19-01-2011, 07:05 PM
  2. trip computer/total distance computer STOPPED!
    By Juzzy21 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-01-2007, 10:10 PM
  3. trip computer
    By vracclaim in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-08-2006, 09:02 PM
  4. VS trip computer
    By Andrew Richards in forum Electrical Wiring / Questions
    Last Post: 20-10-2005, 07:12 AM
