Results 1 to 11 of 11
Thread: Will a vp motor n box fit in a vr?
    vn ss 355, vl, vr, vs ss
    Jan 2010
    Default Will a vp motor n box fit in a vr?
    AS ABOVE.
    I HAVE A VP(FULL CAR) WILL THE MOTOR N BOX FIT A VR?
    IF NOT WHAT IS NEEDED 2 MAKE IT FIT?
    both (Buick V6)
    BOTH AUTO'S
    wraith's Avatar
    wraith is offline Hand over the dog bikkies
    '95 VR Series II
    Sep 2008
    Demonicaland
    VP has a hydraulic gearbox. VR is electronic. To do it will require the loom and ecu to be incorporated as far as I know.
    Jan 2010
    wraith's Avatar
    '95 VR Series II
    Sep 2008
    Demonicaland
    holden vs
    Mar 2010
    should be fine just swap loom and ecu ect as well, everything will bolt up
    Jan 2010
    WRAITH beacuse my gearbox in the vr is ****ed. n where i live there is only 300 people here so it is hard 2 get parts's.
    HOLDENMAN308 what else do i need 2 swap?
    holden vs
    Mar 2010
    just motor box loom computer relly i havent put a vp motor in a vr but iv put a few v6 motors in to other cars and commys and just but all vn vp vr swap around you will soon see what elso you need when you are changing them but if you have a whole car there then it should be easy, (last vr i did the only thing that didnt work was the speedo but it was auto and i put a manual in it)
    Jan 2010
    holden vs
    Mar 2010
    i know thats thers a bit of work if you just put the vp auto in to a vr so if you do the motor as well should fix that
    wraith's Avatar
    '95 VR Series II
    Sep 2008
    Demonicaland
    Theres nothing really to it. Motor, gearbox, loom and ecu. Swap all that and it should be fine. I don't know about the speedo sensor though.
    Jan 2010
    what about the bcm n all that?
  1. every 165KW motor isn't a 185KW motor!!!!!!
    By pjdm1980 in forum The Pub
    Last Post: 30-08-2009, 12:52 AM
  2. [VIC] WTB Starter motor to suit VC Blue motor 202.
    By Drewie in forum Swap / Wanted to Buy / Trade
    Last Post: 11-05-2009, 01:09 PM
  3. wanna swap s1 motor for a s2 motor in a vn
    By Pimpn1 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-01-2009, 05:55 AM
  4. i have a vl 6cyl just had exchange motor put in, the cars factory auto the new motor
    By highmat_8686 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 24-11-2008, 09:32 AM
  5. will a manual box starter motor fit on a auto box motor?
    By lil_oneblue in forum VL Holden Commodore (1986 - 1988)
    Last Post: 03-09-2007, 05:17 PM
