Results 1 to 15 of 15
Thread: need help vs 5ltr no spark and hoow know about the manual computers
    Vs Ss 5.0
    Feb 2010
    Exclamation need help vs 5ltr no spark and hoow know about the manual computers
    Hi people i need help as my vs 5ltr lost spark. I am not sure what to check and wondering if u could tell me a couple of things to check out also i have a manual computer and not to sure what its from. the sticker says "5.0l man IEFI-4". I would love it if someone could help me out on these maters cheers.
    Vs Ss 5.0
    Feb 2010
    do many people know much about this stuff i think i know what the prob is but not to sure what the thing is called. the thing is under the bonet and is located just above the air box. what the fxxk is that thing called. it has something to do with the spark i know that much
    Vs Ss 5.0
    Feb 2010
    strgas's Avatar
    strgas is offline GRA = REAL HP
    Oct 2009
    Vs Ss 5.0
    Feb 2010
    Quote Originally Posted by strgas View Post
    trigger module .
    Thanks mate thats the thing u wouldent know much about the computer at all would u. been searching for it on the net but not a thing to be found
    vnss
    Jan 2005
    s.e melb
    check the ignition module and the coil. chances are one of those two have shit themselves.
    strgas's Avatar
    Oct 2009
    Its common for the trigger module to over heat and burn out internally the first rework for the trigger modules was to remount them between the air box and the inner guard behind the LH headlight to help remove as much heat as possible . check your coil too it may have broken down too .
    Vs Ss 5.0
    Feb 2010
    so the trigger and coil may have gone at the same time u think. what happend when it stoped was it was like it was running out of fuel then just stoped .but before that it had a little bit of a splutter when driving and it was like that for a few days but also it only started happening when i converted it to a manual.
    Vs Ss 5.0
    Feb 2010
    strgas's Avatar
    Oct 2009
    yep id say its cooked . if you open it up i bet it will be brown or black inside the PCB will be well done
    Vs Ss 5.0
    Feb 2010
    so u recon just the trigger or the coil as well
    strgas's Avatar
    Oct 2009
    Vs Ss 5.0
    Feb 2010
    Mar 2009
    by trigger module you mean ignition module right..??
    I had the same problem with my ss the other week.. broke down lost spark, it was a busted coil on mine when i managed to get the old coil out from the back of the block it had a crack around it.
    Mounted my new one on the fire wall so its easier to get to as its a tight fit where they are mounted from factory.
    NEw bosch coil was $77 and problem was fixed, i put a new dizzy cap and rotor button on whilst i was at it total cost $135.
    I did try a new ignition module before i replaced my coil tho just for the fact it was the easier part to get at to check 1st, if you have a spare module or a friend who has one try changing it over 1st, there only connected by 2 plugs.
    If this doesnt fix your none sparking problem then you need a new coil.
  15. #15
    99 Vs SS SeriesIII Ute
    Feb 2006
    Yes I just pulled my coil of and it was cracked on both sides. But I checked my module first by changing with a friend and no joy so coil came out. Now just have to replace.
  1. need help auto to manual in vs 5ltr
    By bigjimy87 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-02-2010, 11:59 AM
  2. help with manual conversion in 5ltr
    By speco in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-10-2009, 09:24 PM
  3. 5ltr and manual conversion for my vp
    By VPS2 in forum General
    Last Post: 13-04-2009, 05:34 PM
  4. [SA] VS Statesman S2 Manual Conversion 5LTR
    By VS5lTR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-11-2008, 07:16 PM
  5. Spark Plug leads Vk 5ltr
    By Sik_Cordz in forum V8 Development and Modification
    Last Post: 05-03-2008, 08:15 PM
