G'Day,
I have a VS ss ute and am planning to overhaul the interier myself instead of sending it off to an expensive detailing shop. Has anyone tried retrofitting vx-vz door trims into a VS. Would be great to hear from anyone for some advice and tips.
hey, sounds like a good idea and good on ya if you wanna do it yourself, i just did mine and you get a great satisfaction for doing it yourself, but about the vt-vz door trims, if you wanted you could, but there would be alot of effing around trying to get them to fit, because you'll have to cut & shape them to fit, then re-upholster and also you might have to put in new holes in the doors to fit the plastic pin behind the trim, but if it was up to me, i'd just vinyl dye them, but if you wanna have a go at it, go ahea man and good on ya for trying if you do, and good luck man.![]()
