Results 1 to 13 of 13
Thread: No Gears + No Tranny Fluid
    impulsive's Avatar
    impulsive is offline Alloytec Racing
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    Default No Gears + No Tranny Fluid
    Just blew the line to the stock trannny cooler on my VR Acclaim losing all my Auto Fluid, andf now i have loat all gears, wondering if no fluiod would be the cause of this and if so how much fluid does it need to get gears back?
    Life starts at 200km/h
    Mar 2009
    yes it will be the cause, no fluid = no pressure = no gears
    it will need what ever the amount you lost replacing before it will move again. with the car running and in park check the level on the dipstick
    White Tiger's Avatar
    White Tiger is offline Semper Fidelis
    VN Executive Wagon VR Berlina V6
    Jul 2009
    Bordertown SA
    21. No movement in any gear: pump failure, or total loss of fluid. R&R, or refill pan
    and find the leak. If out of fluid, avoid running the engine until the trans is refilled to avoid
    pump damage. To check for pump failure, check fluid level with the engine off, then start
    the engine and recheck fluid level. If level does not go down when engine is running, the
    pump is broken.
    Mar 2009
    Quote Originally Posted by White Tiger View Post
    pump is broken.
    didnt he just say he blew a tranny line?? so the pump will be fine (so long as it wasnt ran dry) and he knows where the leak is....
    impulsive's Avatar
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    Jul 2009
    Bordertown SA
    Mar 2009
    impulsive's Avatar
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    i thought there was quite a bit of fluid lost, hopefully its not as expensive as oil
    Mar 2009
    impulsive's Avatar
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    VZ SV6
    Oct 2008
    Newcastle NSW
    happened to me too, the problem is were you driving for a bit and realised it was slipping like in neutral before you stopped? if so you may have caused some damage driving with low fluid... certainly happened in my case, once it was refilled it seemed fine but started slipping on kickdown bigtime (flaring on 3-2 downshift, and also really slurred upshifts when not at full throttle)
    vs exec
    Jun 2008
    impulsive's Avatar
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    Lol Mate, im just going to score some ATF the Lavs use at work.. at least i think they do, Should be right..
  1. to much tranny fluid
    By ratz26 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-11-2009, 07:11 AM
  2. put in 3.5 litres of tranny fluid still not enough wtf?
    By Gazza2005au in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-12-2007, 04:19 PM
  3. No Gears in Tranny
    By kniever in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-12-2007, 01:35 PM
  4. gushing tranny fluid...traumatic indeed
    By Vk-5ltr Berlina in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 31-01-2007, 09:55 AM
  5. VY Auto Tranny Fluid Change
    By TheJack in forum VY Holden Commodore (2002 - 2004)
    Last Post: 15-10-2006, 04:55 PM
