I have just put a VS v6 (non ecotec) into a VR commodore. I used the original VR G/box & didn't change the ecu etc...
Should I of done this? Does it matter. I didn't think you could get a VS non ecotec V6 but the wrecker was certain it was from a VS.
Thanks
all vs v6's were ecotecs
Black, Red leather, 20" Pentagons, Red walls, Lowered, OTR, Mafless, 3.9s, Diff dumpers, 341rwhp...
185i, Chasers, Flappers, Venetians, Sunvisor, Twin diff dumpers, 194rwhp...
unless it was originally from a VR before you got it, just because it came out of a VS dosnt mean it wasnt in a VR first.
Say it was out of a commodore which wasn't a VR would the ECU etc... be the same or would it really need to be run off the correct ECU?
I'm thinking about doing this but I don't really want to have to change my auto, (shift kit in it, etc)
u can use the auto but the wirng inside is 1 wire different something do with the speedo u can use the vr extension on the tranny and pull the pan off and change the loom inside. i just changed my vr to ecotec and that was a headache i used a vx engine with a vs manual loom with a t5 instead of a getrag and changed the whole body loom to a statesman. there is a lot of little differences that u wouldnt think of between vr and vs
