Results 1 to 9 of 9
Thread: indicator stalk/high beam issues
    vs exec
    Jun 2008
    Default indicator stalk/high beam issues
    hey guys my high beams are getting really touchy and are coming on with slight bumps to the indicator stalk and so come on sometimes when indicating. anyone had a similar issue? im guessing its just a lose wire on the stalk somewhere
    edals's Avatar
    edals is offline Blues Brother # 1
    VY 2002 Wagon, VX 2001 Sedan
    Sep 2008
    QLD/NSW Boardish
    Hey Mate.
    Got the Same problem with the VX. Its not a Loose wire, its the inside parts of the stalk its self. You can get a new stalk for about 60$, I tried pulling another apart but it just went all wrong lol.
    Hope this helps ya.
    vs exec
    Jun 2008
    calais24/7's Avatar
    calais24/7 is offline Mucca Mad Boys
    VS Calais II 5L, 98 rodeo v6
    Jul 2009
    Steering wheel will have to come off and it should be a few screws to get the stalk off an unplug the plug
    seraphic06's Avatar
    seraphic06 is offline Woodgrain Nut
    VS Esteem SII Wagon
    Sep 2008
    Adelaide, SA
    The steering wheel shroud - not the wheel itself - just needs to come off. Undo the screws at the bottom of the shroud and then unclip the stalk. You will also need to undo an electrical connector if you have crusie control installed.
    vs exec
    Jun 2008
    calais24/7's Avatar
    Jul 2009
    vs exec
    Jun 2008
    getting a new stalk... i dont have cruise control but im thinking about installing it soon. should i get the cruise stalk? will that work for indicators and high beams for now without having the cruise control module. and is it then hard to install cruise?
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    This thread will tell you most of what you want to know:
    How do I install genuine cruise control on a vs executive?
  1. how to switch from high beam to low beam?
    By Shogun in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-11-2009, 12:34 PM
  2. High Beam/Parkers work, Low beam doesn't?
    By 003KWK in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-11-2009, 05:15 PM
  3. Indicator Stalk
    By sicko in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-07-2006, 03:04 PM
  4. High Beam lights glowing when on low beam ?
    By Madhouse_Dave in forum Electrical Wiring / Questions
    Last Post: 03-09-2005, 10:15 AM
  5. VK Indicator Stalk/High Beam
    By Chode in forum Electrical Wiring / Questions
    Last Post: 14-10-2004, 08:09 PM
