I want to know if there is a step by step guide on putting a LS1 v8 into a VS this is for a project car all the work will be done by me and my mechanic so labor price doesn't matter i already have the motor,loom, computer and auto trans but need to know what else i will need and how much it will cost for the parts a Step By Step would be good
you need to contact castlemaine rod shop they sell conversion kits, this is not a bolt in mod.
Try a search cause im sure youll find countless threads.
Do u know his username on calaisturbo.com
yep. 'exec5ltrvl' a few other blokes have got threads on the same subject but this guy's is the best.
apparently some bloke by the name of 'roadwarrior' has another good thread on this over at the street commodores forum, so i've heard anyway. i havent bothered checking it out yet.
:edit: make that 'road_warrior' at SC, its the one surfwagon posted the link to but i'm not sure its workin
Check out this thread on SC forum.
He even manufactures some of the parts needed as he found some of the more common conversion parts left a lot to be desired.
He also tells you what mods are needed to your K frame to make sure the engine fits with out touching anything.
Be wraned it is a long thread but well worth the look if you are serious about an LS1 conversion.
http://forum.****************.com.au....php?t=8509682
Cheers SW.
HSV VZ LS2 Senator, Stealth2 cam 307rwkw.http://forums.justcommodores.com.au/...ados-blue.html
VS11 Berlina L67 super6 wagon 196rwkw. http://forums.justcommodores.com.au/...ified-cai.html
I still don't understand why Street Commodores website is blocked under the filter....
A mate of mine said there is a place that does the full conversion would any one know where it and the name of the place i don't care how much it costs this is something i really want to do to my car so I'm going to do it regardless of how much it costs
Ive pretty much finished doing this conversion and it really wasnt that hard. I dont have any training and have never done an engine conversion before. Apart from the wiring/some of the exhaust ive done the whole thing myself. It is generally pretty straight forward though I wouldnt recomend using the CAE mounts/Extractors together as I had to modify mine to fit. Also with spacer plates in the engine mounts (CAE style) the K frame does not need to be cut as for me there was sufficient clearance once the spacers were installed. Send me a PM if u got any questions
lol @ step by step guide. If only it were so easy.
Doing the same in a VN right now.
WTB: mulberry VN interior parts
