Results 1 to 7 of 7
Thread: battery light flashes
    benno9911's Avatar
    benno9911 is offline Donating Member
    03 VY S2 Exec
    Jan 2010
    Warrnambool
    Default battery light flashes
    it comes on when i sit below 1000rpm for a bit but goes away as soon as i get above it i cheack my error codes and i am only getting error 83 dose anyone know whats going on
    vs commodore
    Oct 2009
    Tamworth NSW
    Check the alternator wiring where it joins the alternator,the wiring can get hot which corrodes the wire and causes a bad contact which makes the charge light come on.Also check the alternator output.It should be around 13 volts or more with the engine running(idling).The error code 83 is an auto transmission fault.Try clearing the error code by disconnecting the battery for a couple of minutes.Then see if the error returns after you have been for a drive.
    VN S1 (was VR) V6 Hilux
    Apr 2009
    The alternator regulator brushes may be worn down to nearly not touching. Remove the regulator and see if the brushes are gone. They must be about 7mm minimum length I think. Go see an auto elec with the regulator to confirm if you are not able to tell.
    benno9911's Avatar
    03 VY S2 Exec
    Jan 2010
    Warrnambool
    chrisdoesitbetter's Avatar
    chrisdoesitbetter is offline | → ³8°º™ ← |
    VR 3.8L
    May 2009
    Quote Originally Posted by v6lux View Post
    im with this lad, i had the same problem only mine went from flashing to being constantly lit. $65 for the regulator pack and shes fixed.
    benno9911's Avatar
    03 VY S2 Exec
    Jan 2010
    Warrnambool
    ok well i do have a spare vn sitting out at my one of my mates farms are that i uses for parts are they the same alternator
    VR 3.8L
    May 2009
    dont quoe me on this but i think the connections are the same, the vn just has an external fan.
  1. battery light with brand new battery
    By andyli in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-03-2010, 09:48 AM
  2. Engine stops, fuel light on, battery light on GOODBYE
    By scarletx in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-06-2009, 03:43 PM
  3. Battery light & Check Engine light
    By Sledge in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-09-2008, 06:30 PM
  4. VY Berlina Interior light flashes when door is open
    By MadDawg in forum VY Holden Commodore (2002 - 2004)
    Last Post: 27-05-2008, 12:17 PM
  5. Hazard Light Button - Flashes
    By Sammy in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 15-07-2005, 03:36 PM
