hey all , so the front slotted rotors on my vs commodore are ratshit and need to be replaced , im wondering if i should upgrade to the vt brake upgrade has anyone done this olready is it easy to do and how much is it likely to cost ? , i have 19" wheels on the car so the added braking power would be an advantage
i was actually thinking on getting the one on ebay under vt brake upgrade if you ebay that you get the actual vs upgrade kit has any one used this kit or have anything to say about it cheers
Hi mate,
If you're looking at doing a front brake conversion you're better off going to a VE setup because they have smaller pistons for better pedal feel, and less caliper flex. Complete kit details can be found here:
VE Twin Piston Upgrade Package suit VB-VZ Commodore!!!
Regards,
Greg
- GSL RallySport - Ph: 1300 884 836 -
Sick of paying too much for high performance brake pads? Want high performance and cold bite with low rotor wear?
- QFM Performance Brake Pads -
Also specialising in
- DMS High Performance Shock Absorbers - Monit Rally Computers -
