Hey all,
Yea, wondering if my 94 VR Acclaim series 2 would have IRS? looking at a Catback Mandrel bend system (it may need a twin bend) by redback on ebay, for $189 excluding postage. or i'm considering going a mandrel bend system through my local muffler dealer, (carline mufflers NSW) aaaaannndd, also considering doing my own fitting at work, so i have access to all the tools etc etc. but my only probleme would be if they realise another bend needs to be made, in which i couldn't do..
its bout $250 fitting so i'm considering whats best option.
Ideas all?
Post opinions/ideas
Carl.
When you buy a catback system just make sure its designed for a IRS rear end which would mean it will bolt straight up.
lol ^^
look at your differential ( i hope you know what that is) IRS models will have a rubber boot and drive shafts on each side whereas a solid diff is solid lol
The exhaust goes over the axle on a live axle and under it on IRS. That's the easiest way to tell if you don't know what an IRS diff looks like.
Or you could just say, No a VR V6 doesn't have an IRS rear-end
(unless optioned) _ in which case there will be a badge under the radio that says 'IRS'
It will be IRS but just to be sure look under it, if it looks roughly (alot) like a VW dune buggy then it's IRS. Pretty much a straight copy of the VW design
