Results 1 to 12 of 12
Thread: vs manual
    dan202's Avatar
    dan202 is offline ITZ A PIG
    I HOT VR
    Jul 2009
    lancefield
    Exclamation vs manual
    hi there ive just converted my vr to a worked vx ecotec i had this setup in a vn and went hard it was using a vs auto loom on a vx engine with a no vats computer and chip and i put a vs manual t5 loom on. just doesnt move as in goes hard, is a getrag ecu the same as a t5 ecu. and what does no vats mean??? i heard it was for a bcm replacement but the vn had a bcm simulator aswell. any ideas
    89 vn berlina wagon,94 vr clubby mock up
    Mar 2010
    bendigo
    VS Berlina 3.8
    Dec 2008
    Quote Originally Posted by holden_2100 View Post
    yea got an idea dan get a new car u goose!!!
    That was such a helpful post wasn't it.
    dan202's Avatar
    I HOT VR
    Jul 2009
    lancefield
    VSIII s-pak ute 3.8l 5-speed
    Feb 2010
    Without knowing much i would assume the computer thinks the car is in "D" or something, so the startor wont engage, i bet ya if u turn it to ignition and roll start it itll go.
    i could be very wrong but thats a common issue with auto -> manual conversions or in your case, manual -> manual conversion lol
    check and double check the wiring
    What exactly does the car do?
    does it show voltage on ignition
    does it crank
    does it have fuel
    does it have spark
    id be checking the basics first and then going from there
    dan202's Avatar
    I HOT VR
    Jul 2009
    lancefield
    the cars runs and drives goes hard but it went a lot harder in the vn i have fault codes for auto and injector voltage fault, intermitent speed sensor and needs knock sensors, idels like a bucket and then it picks the revs up and drops back down, cam has a lot to do with it. just would like to know what no vats mean.
    vs series II berlina
    Sep 2005
    i had a injector not firing when i did my conversion check all injector plugs and my vs runs on a vn loom and lovs it
    dan202's Avatar
    I HOT VR
    Jul 2009
    lancefield
    vs loom hey i didnt tihnk to run mine i a vr loom makes sense tho just got to drag the sensors for tps and iac and run a map sensor, she runs on all 6 it had a small exhaust maniflod leak fixed that and runs a bit better i might re-earth the oxy sensors 1 is different to the other it might have somthing to do with it after 20 minutes of ideling it runs ok, im taking the bungs out of the block and putting in the knock sensors, does any1 know what knock sensors do??
    Sep 2005
    if the motor pings it adjusts timing they are good to have vr motors have one vs has two change to the vr manual loom its heaps better
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    no VATs is the vehicle anti theft turned off so it runs with no bcm .if theres no knock sensors wired in she will be running pretty sluggish will have max timing retard due to them being missing.but as said above swap to vr/vn wiring and ecu.best and cheapest is a vn loom and ecu its the same as vr anyway just easier to find.will need a tune though is the only downfall
    dan202's Avatar
    I HOT VR
    Jul 2009
    lancefield
    nice mate helps i got a vs t5 engine loom and just changed the body loom to suit so not changing back to a vr loom i have 1 but its for buick not ecotec. i have a t5 manual ecotec computer in the wind ill get it and put the knock sensors on, little scary to think about she already is a machine.
    dan202's Avatar
    I HOT VR
    Jul 2009
    lancefield
    done the knock sensors and heaps better at idle and more pokey just got to get a manual computer in and see what happens
  1. [WA] FS: Wreck VL Wagon 5 Speed Manual, Manual Steering
    By VP Wagon in forum Parts And Other Items For Sale
    Last Post: 13-09-2009, 11:22 AM
  2. Please Help, Doing manual conversion and i used the auto flexplate bolt on manual fly
    By xtreme_sony in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-06-2009, 08:52 PM
  3. VN manual now with a VR Series II motor w/auto loom but a manual. Crank'n issues
    By Illuminatis in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-03-2009, 07:03 PM
  4. 4spd manual to 5spd manual
    By Orloxsis in forum General Discussion
    Last Post: 11-04-2008, 08:57 PM
  5. WTT: camira service manual for a VP sevice manual
    By sparra_gump in forum Swap / Wanted to Buy / Trade
    Last Post: 02-12-2005, 01:18 PM
