Results 1 to 3 of 3
Thread: ?blown head gasket or inlet manifold ?
    vy calais .vs commodore
    Sep 2005
    blacktown
    Default ?blown head gasket or inlet manifold ?
    hello i am after a bit of help i have a vs v6 it is going threw a bit of coolant and it has milky junk a round the valve springs and under the oil capand when i go up the ramps in the local parking lot the temp gage goes up into the red i took it to the mecanic and was told the head gasket is on its way out at chamber 7 before i pay big $$$ i would like to know the difference between the inlet manifold gasket and head gasket blown symtoms
    sik_dose is offline Hybrids. Cars for fools.
    1986 VL Calais 5 Speed
    Feb 2010
    If thers a milky substance around your valves im beting head gasket, that milky stuff is coolant and oil mixed togeather, if you want to be sure, take off your inlet manifold and inspect the gaskets. A head gasket isnt a hard job to do your self and it works out cheaper to just buy parts.
    vs commodore
    Oct 2009
    Tamworth NSW
    It dependes where the gasket actually blows out.Sometimes there is no water mixed with the oil sometimes there is,(the engine oil goes like mikly slime),sometimes it will just blow the coolant out the overflow,or sometimes it just pumps coolant through the engine and out the exhaust.You would have to do a compression test on the engine to find the cylinder/s effected.And also have the cooling system pressure tested to see if its leaking around the inlet manifold gaskets.If the head gasket is blown,the inlet manifold has to come off anyway.
  1. Inlet Manifold (Gasket???)
    By boojak87 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-01-2012, 02:44 PM
  2. blown head gasket or inlet manifold
    By bulldog79 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-03-2010, 11:41 AM
  3. inlet manifold, worth doing head gasket as well?
    By The1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-03-2010, 10:48 AM
  4. inlet manifold gasket
    By gungazza in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-01-2010, 11:33 PM
  5. Inlet manifold gasket
    By gogoboygareth in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-11-2008, 07:02 PM
