+ Reply to Thread
Results 1 to 6 of 6
Thread: VR 5ltr problem
    mr bt1
    Mar 2010
    Default VR 5ltr problem
    start car runs fine start driving then battery light starts popppin up and engine check light comes on car starts to lose power then cuts out get the car jump started only to have it do it all over again is this an alternator problem?any feedback much appreciated
    Mar 2009
    Mar 2009
    check voltage output when running should be around 14v, If its lower will prob just be a case of replacing the brushes on the reg in the back of the alternator. You can check the brushes by pulling the reg out to see how worn they are.
    You can buy a replacement reg for around $50 or you can buy the brushes and solder them on to your current reg for $5
    VS Caprice
    Feb 2008
    I concur with Westbad. I have had to replace the regulator on mine - a lot cheaper than the standard $350 swap from an autoelectric. Also, check your main connection to the alternator - it tends to corrode and cause voltage problems.
    slepar's Avatar
    slepar is offline omg duz it like...dose?? slepar Executive
    vn ss
    Mar 2007
    exactly the same thing happend to my vt 5ltr i thought it was the battery so i replaced it it was fine for about 2 days then BANG happend again lol, turned out to be the alternator, couldnt hurt to change it anyway
    doin skids for the kids and doughnuts for the grown ups
    Vr Berlina 195i
    Apr 2009
    west side
    Most likely alternator, when battery light comes on means voltage too low im not sure if it displays when its to high, as westbad said anything between 13-14v is normal anything under 12v will light up. Just pull apart ur alternator and check if the brushes are stuck sometimes one gets stuck and doesnt make a good contact
+ Reply to Thread
  1. 5ltr VR Calais start problem
    By Pete.M in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-01-2010, 11:09 AM
  2. vs 5ltr fuel problem??
    By mantavs96 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-12-2009, 08:57 PM
  3. vn 5ltr engine light problem
    By slepar in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-05-2009, 11:01 PM
  4. Help: VS 5ltr problem
    By stunnd in forum Electrical Wiring / Questions
    Last Post: 26-06-2005, 01:52 PM
