Results 1 to 5 of 5
Thread: vr2 engine vibration just off idle to 1500
    moff_man's Avatar
    moff_man is offline operation HQ under way.
    95 VR II berlina wagon v6, 72 HQ ute 253
    Nov 2008
    Default vr2 engine vibration just off idle to 1500
    just wondering if anyone has experanced a engine vibration at just off idle to approx 1500 rpm, hot or cold. load or no load netural or drive
    just replaced injectors, have way beter fuel ecco now but vibration still there
    plugs leads oil fuel filters all replaced.
    the car has been sitting for 6 years, so im thinking it could be a lifter stuck or an air leak. also whistles under hard acclaration
    any ideas before i start ripping it apart....
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    This is a long shot moff man, but I thought I'd throw it in.
    What I saw many years ago on a Jap car which had been sitting for many years and also had a rubber harmonic balancer was that the balancer "flat-spotted" from having the belt pressure on the one side of the balancer for a very long period. This was only noticed when the fanbelt would not run straight (flapped up and down) and there was also a vibration from the engine. This eventually fixed itself much like a tyre left sitting with weight on it will flat-spot but will smooth out once it warms up.
    moff_man's Avatar
    Nov 2008
    rb30 vl engines do this also, i should of know lol, i might give it a bit more time it seems to be getting better, but after a week i thought it shuld of been gorn.
    it was realy bad when i first picked it up (from outback nsw) but it had no oil in the engine and no auto fluid in it.
    injector cleaner and lifter free will do for now and ill check on the ballancer.
    i have done less than 1000km and about to do another oil change.
    vr series 2 v6
    Oct 2009
    nsw
    Quote Originally Posted by moff_man View Post
    just an idea, vibration or slight knock? i just had this problem recently and it was a cracked fly wheel
    and main bearings get worse when you come off idle, wanna hope its not that
    Vs eco 3.8, extractors, 2.75" exhaust, roller rockers, cammed, bored out 20, t5 manual, rolling on king springs all way round with monroe gt shocks all way round, every door has a ding but looks can be very deceaving
    moff_man's Avatar
    Nov 2008
    deffently a vibration no knocks no pinging not even any ballance shaft noise till she warms up ( i thought at first the ballance shaft wasnt attached till it started making noise) the inspector who did my blueie said the motor moves around a fair bit but the mounts are all good.
    ohh im also a quillifyed mechanic im just asking what other people have experanced, as i dont get 2 sec to look at my own car its realy anoying, so if i can get some people with the same sorta problem i can check that first. spose i better find some time for it i guess
  1. Exhaust vibration at idle
    By Danoz in forum VE Holden Commodore (2006 - ?)
    Last Post: 13-08-2009, 09:04 AM
  2. Help VY II Vibration on Idle
    By jethro in forum VY Holden Commodore (2002 - 2004)
    Last Post: 04-11-2007, 10:41 PM
  3. Engine vibration around 1200-1500 rpm
    By Gunship in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-01-2007, 09:51 AM
  4. Idle Vibration
    By tommyboy84 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 30-10-2005, 08:36 PM
  5. pulse idle at 1500 rpm on coasting
    By pcp20us in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-09-2005, 12:15 AM
