Results 1 to 22 of 22
Thread: How to bypass VR immobiliser in key???
    vr commodore
    Jan 2010
    Default How to bypass VR immobiliser in key???
    I can't not deactive the immobiliser to start the car, is there a way I can bypass it or disconnect it?
    vn_v6's Avatar
    vn_v6 is offline Blumpkin
    87 vl limited edition
    Aug 2009
    victoria
    no-oones gonna answe4r, and the jsut commodres guys are gonna accuse you of stealing and ect meh
    Quote Originally Posted by Swordsy View Post
    If keyboads were cars, I'm sure half the people here would have been run down by now :P
    Quote Originally Posted by danja View Post
    GM: Has millions of dollars and highly trained engineers.
    Some guy in his backyard: Has a hole saw.Discuss.
    Quote Originally Posted by illusionalvr View Post
    just tow it around on a trailer and tell everyone its a turbo putting out 770 horses.
    Mar 2009
    yes you can. turn the ignition on so dash lights light up, leave like that for 40mins minimum then the car will start, if you turn it off again you have to wait another 40 mins.
    vr commodore
    Jan 2010
    my partner is stuck at work and can't get home he finishes at 4am! we just changed the harmonic balancer and crank angel sensor today!
    We aren't stealing any car we are stuck!!!
    Mar 2009
    see above^^ its the only way to do it.... short of hacking the electrics to bits..
    vr commodore
    Jan 2010
    westbad thanks for that
    just thought i would put in we are not planning to steal a car!!
    i will call him back in 20mins to see if it has worked!
    Thanks again!
    James39's Avatar
    James39 is offline Gave up on VL's
    1995 VS Acclaim & 1992 Holden Barina
    Jul 2009
    Newcastle NSW
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Maybe the OP is talking about an aftermarket immobiliser and not the factory one....many Commodores have these fitted and disabling them can be a problem.
    Mar 2009
    Quote Originally Posted by hako View Post
    lol i assumed they were talking about the factory fitted immobilizer.
    If its aftermarket hes in trouble
    vs commodore
    Oct 2009
    Tamworth NSW
    If its a VR commodore with standard factory ignition keyhead (key fob) type immobiliser than it takes 45 minutes with the ignition key in the on position for the immobiliser to be bypassed.The red flashing security light on the centre of the dash/console will stop flashing when the time is up.
    vr commodore
    Jan 2010
    James39
    When we bought the car they had to replace the ignition and got a code from holden does that mean it's a genuine one???
    Also can we just change the battery, isn't it coded in some way to the computer?
    vs commodore
    Oct 2009
    Tamworth NSW
    Yep, its a genuine one then.The 45 minutes with the key in the on position will bypass it.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Quote Originally Posted by Brett_jjj View Post
    If its a VR commodore with standard factory ignition keyhead (key fob) type immobiliser than it takes 45 minutes with the ignition key in the on position for the immobiliser to be bypassed.The red light on the centre of the dash/console will stop flashing when the time is up.
    Just for info, my owners manual states that even if the keyhead battery has insufficient power to operate the central locking, sufficient power will still remain to disable the immobiliser once you get the key in the ignition (you have to open the drivers door with the key). I've never tested this but that's what it says.
    vr commodore
    Jan 2010
    THANK YOU
    It's worked!!!! It has been disabled it's self
    Thank you so much everyone for helping!!!!!!!!
  15. #15
    Mar 2009
    make sure you tell him if he turns the car off it wont start again for another 40-45 mins what ever the time is..
  16. #16
    vr commodore
    Jan 2010
    westbad
    yep did tell him to make sure he put key in 45mins for he leaves, thank you for your help
    Also can we just replace the battery in it? or do we have to buy another key compltely cause it's coded?
  17. #17
    Mar 2009
    you can replace the battery, do a search there is a how to on this on the forum, it is a sealed key but you can cut it open change the battery and glue back together
  18. #18
    vr commodore
    Jan 2010
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
  20. #20
    Mar 2009
  21. #21
    vr commodore
    Jan 2010
    Mar 2009
  1. Bypass immobiliser without key??
    By Bungle in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-04-2012, 08:01 PM
  2. bypass stock immobiliser
    By sycvs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-12-2011, 05:48 PM
  3. How to bypass VR immobiliser in key??
    By ryan1980 in forum Electrical Wiring / Questions
    Last Post: 21-05-2009, 08:07 AM
  4. Bypass SRS
    By lil_mickey in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-04-2009, 11:07 PM
  5. bypass
    By markovr in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-05-2004, 10:41 AM
