Results 1 to 9 of 9
Thread: degreased the motor slightly, now running like a deisel
    vs calais
    Dec 2008
    Default degreased the motor slightly, now running like a deisel
    hello everyone,
    i degreased my v6 motor today, didnt do the whole thing just the rocker covers and strut tower panels..
    now the car is running like crap, puffing out the exhuast, and it feels like a deisel, doesnt accelerate idle or accelerate smoothly, scared to drive it
    wat are your suggestions?
    cheers
    azkwazere is offline Ahhh Yes, Ahhh Yes....
    VP 5-SPD / 24-SPD Racer Hybrid
    May 2005
    .....SE Burbs
    you've:
    A: Killed a sensor with chemical
    B: knocked a sensor out by accident
    Go back and check everything is plugged in
    aZk.
    Wanted to buy:
    1. T5 V8 Bellhousing and Clutch fork assembly suit VP
    2. V8 Tail Shaft, T5, Suit IRS VP
    3. T5 VB Gear Box
    PM Me if you got what i need...
    Quote Originally Posted by ryno_vrx View Post
    honestly i doubt it will happen cause kanye west will just interrupt Armageddon anyways
    vs calais
    Dec 2008
    hi mate, checked, and everything is plugged in...
    i didnt put much water on it either, only on the top where the rockers are... didnt even get the front of the motor
    vs calais
    Dec 2008
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    I'd remove the plug leads from each plug and also at each coil and let them dry. Let them lay close to where you removed them from so they don't get mixed up. To hurry things up do this in the sun or rig up a fan to blow air over the engine. You may also have gotten the coils wet but when dry they should be OK.
    I'd also pull any connectors in the area you degreased apart and check there is no water there.
    Hope this helps.
    woteva's Avatar
    woteva is offline NEED 4 SPEED
    VRII V6 Auto Wagon
    Jul 2005
    Adelaide S.A.
    If it's running like a diesel, wouln't that be more efficient and you will get more kms per tank
    You most likely got some water in where you not suppoed to. As said above, take off the plug leads and let them dry out. If you have compressed air, blow into connectors etc. to any water out.
    http://woteva.tk/
    If it ain't broke... I can break it for you
    vs calais
    Dec 2008
    well found the problem ppl,
    2-5 coil is dead... no resistance at all... put a new coil in and car runs beautifully again
    would anyone have any ideas on why this happened? i didnt really get them wet, and there pretty sealed within themselves
    N/A
    Nov 2009
    Quote Originally Posted by admir87 View Post
    Is there a crack in the housing? maybe it was hot and the cold water was enough to crack the housing and allow water ingress.
    www.thewheeldeal.com.au
    Ask me for a great deal on tyres & wheels shipped Australia wide.
    vs calais
    Dec 2008
    nope no crack in the coil
  1. [VIC] VR motor for sale not running
    By Phoenix21 in forum Parts And Other Items For Sale
    Last Post: 26-11-2008, 07:32 PM
  2. degreased motor now wont run...help needed urgently
    By canabl in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-11-2008, 12:45 PM
  3. Motor not running right.
    By DANNY8 in forum General
    Last Post: 09-07-2008, 11:07 AM
  4. Running in a motor
    By DANNY8 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 16-05-2008, 06:53 PM
  5. Running in new motor
    By bajdas in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 03-09-2005, 11:37 PM
