Hi everyone, I'm having a few dramas getting my vs commodore through a rwc theyve knocked me back on the front windscreen demister not working, all the vacuum hoses look to be connected just fine but it's still only blowing at the feet level. any ideas what it could be would be much appreciated
cheers
Have you checked the vacuum hose at the rear of the intake manifold?
MY RIDE
i just had the same issue. was told cause it will only blow at feet it is a vacume issue.
vs heater/fan problem
i had some good advice on that thread bout it.
ended up being a small split in vac hose near heater tap.
only milk and juice should come in 2 litres
ok..I found where that went but it didnt fix it...whereabouts is this canister?
