Results 1 to 9 of 9
Thread: Upgrade VR to VS Engine & Transmission
    DJ Frestyla is offline DJ Frestyla
    VR Belina, VR Calais 5.0L
    Mar 2010
    Yass NSW
    Default Upgrade VR to VS Engine & Transmission
    Hi All,
    I recently blew my transmission in my VR Wagon, but got hold of a VS nice and cheap.
    Whats involved in doing a full engine and trans transplant into the VR ??
    VR Caprice
    Dec 2005
    With the Ecotec a fair bit I was told. If it's V8 then with a doner car it is a matter of patience and time. The ecotec needs most of the electrics swapped over as well as BCM and ECU and that means some wiring alterations.
    Mar 2010
    Yass NSW
    thanks, both are V6, so ill look at taking the wholw wiring loom from the VS (donor) then , plus ECU and BCM, ill post back up and let you know how i fair.
    Mar 2009
    easy swap, you just need to use everything of the VS and put it in to the VR you need the engine loom and ecu from the VS, BCM can be left alone.
    The VS loom will plug in to the rest of the VR loom under the dash (near ecu)
    Mar 2010
    Yass NSW
    Awsome, im picking up the VS on wed, so ill crank strait into it, thanks again
    VP Series II V6
    Aug 2005
    Hunter Valley NSW
    Dudes, What would be involved in replacing a VP motor with a VR motor? I'm guessing not much, they are basically the same, right? Oh and if anyone is cluey with auto gearboxes please let me know..
    VR Caprice
    Dec 2005
    some functions in the BCM are different. You may also have to modify the plugs that plug in near the Battery. I know I had to when I did my conversion when I put a VS 5L into my VR stato, I had to use the VS loom due to damage. It was easy it's just a matter of swapping the colours to match.
    mrc25381, I would assume it would be a straight swap as they are the same motor.
    fkford is offline Love The Beast!
    VS exec S2
    Mar 2009
    if u have a donor vs with everything in it. just swap everything over. EI engine, trans, computer n looms and possibly engine mounts and exhaust manifolds
    stop droolin
    vh 5lt turbo and vs 5lt commodore
    Mar 2010
    yarrambat
    hi im doing the same conversion at the moment im having trouble wont start its ecotech into vr iv been told u will need to change the pins on the loom to use a vs bcm in ur vr dash loom.( so i have been told) and the plugs are diffrent in the engine bay there behind the booster on the vs but on the vr its next to the battery it will reach but one of the plugs are diffrent ones a 5 pin and one is a six pin cange the wires over matching the wires you will be left with a pink wire wich just needs a 12v ingniton feed i think. vs 5lt just leave it it dosent do eanything iv my vs 5lt the pink wire gos about 1m into the loom then stops . good luck ill let u know how i go.
  1. vh engine upgrade
    By 3.8vhCoMMy in forum V6 Development And Modification
    Last Post: 15-11-2009, 02:59 PM
  2. Engine VS Transmission
    By cypher967 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-01-2007, 04:21 PM
  3. Upgrade to VS engine (on my VP)
    By CLE in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-10-2005, 05:25 PM
  4. VK engine upgrade?
    By oscar_dre in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 08-08-2005, 08:38 PM
  5. VN Transmission Upgrade
    By James C in forum V6 Development And Modification
    Last Post: 02-07-2005, 01:06 PM
Tags for this Thread
