Results 1 to 15 of 15
Thread: 5 litre not happy when warm :(
    vs II 5L
    Mar 2010
    south coast, NSW
    Default 5 litre not happy when warm :(
    hi all im new to this site but hve been keeping an eye on you all for a while
    basicly i have a vs series 2 with 5 litre i have extrctors, 3" exhaust and good leads (need that cai) the motor runs fairly well but once it has warmed up it devolops a slight miss (which can come and go) when trying to cruise say around the 1500rpm mark now if i put my foot into it this will normally clear out but comes back as soon as u get back to low revs .... once this has started if i pull up at lights i have a pretty lumpy idle but the revs will stay steady at around 800. im stumped as to what this could be any help would be greatly apreciated , i would like to avoid the many $$$ this is likely to cost me at a shop
    thanks hamish
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    G'Day Hamish and welcome to the forum. First thing I'd do is a codes check: Checking error codes VR/VS (Revised)
    Are the plugs fairly new and gapped correctly...also leads.
    Your vehicle sounds like something I would lose my license in.
    Mar 2009
    its gotta be time you upgrade your VS to V8 Hako!!! would make an awesome "projects" thread or how to ;-)
    vs II 5L
    Mar 2010
    south coast, NSW
    thanks for the reply guys, leads are new and plugs look good but i might need to put another set it, im going to do a code test now , (paper clip haha lets do it) let you know what comes up
    vs II 5L
    Mar 2010
    south coast, NSW
    ok 12 12 12 and 12 12 12 lol just as i suspected the commodore computer fails again. dose any 1 actually ever get a code up.... now my theory was because it can be fine then all of a sudden develop the miss wouldnt this mean my electrical system was ok ? correct me if im wrong please but i thought if it was plugs or leads that it would be constant ?
    VS II 5 ltr Berlina Wagon
    Apr 2004
    It could be your ignition module. Does your tacho bounce all over the shop when it's missing ????
    Mmmmm V8
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Quote Originally Posted by westbad View Post
    Yup...would be great, for a short time, then no rear tyres (shredded) no license (suspended).............probably get my name in the papers...hey, I'd be famous!!!
    Nothing like a V8 - on YouTube, search for "stickshift" by "the Duals" - it's a 45 from '61 with the sound of a Henry V8 and a stick change....magic.
    http://www.youtube.com/watch?v=uoLj5kQ-TWs
    vs II 5L
    Mar 2010
    south coast, NSW
    Quote Originally Posted by vsv8berlinawag View Post
    hey no mate tacho is fine but my speedo dose have its own mind at times
    well its going to wait till monday ,, new leads plugs and dizzy cap/rotor will see if that makes a difference, im hoping its not the ignition module at $560 id rather set her alight
    MasterOfReality's Avatar
    MasterOfReality is online now Thats Dr to you.....
    VP HSV Enhanced Calais, 2006 Suzuki Grand Vitara
    Feb 2004
    Where the mines are
    Mar 2009
    cracked dizzy cap or loose lead? i had the same on mine a while ago and one of the leads at the dizzy end had come loose.. found this out when i went to fit the new dizzy cap and rotor button
    Didnt bother fitting the new cap as the miss had been fixed.. ill change it one day when i get the time.
    The dizzy caps are a pig to change on the 5ltrs due to there location, i always find the best way to do it is to unclip the cap take it off with leads still attached, swap the leads to the new dizzy cap one at a time then put the cap back on, its a tight fit but take your time and you will be alright.
    If you haven't done already whilst your doing the dizzy cap it is worth while moving the coil, its bolted to the back of the block next to the dizzy, if it fails (like mine did) they are a pain to get at so relocate it to a suitable place on the firewall and extend the wires going to it so they reach will make your life a whole lot easier if and when it fails.
    vs II 5L
    Mar 2010
    south coast, NSW
    where can i pick up a reco ign. mod from ? any where online ? and how much should i be looking at ?
    im hoping it is a dodgy lead or plug but it has me stumped how sometimes its perfectly fine,
    and yeah they put the dizzy an coil in a ridiculous spot
    Mar 2009
    Apr 2004
    There are some mobs that supposedly recon them for around $100 swap over.
    Mmmmm V8
    Apr 2004
  15. #15
    vr acclaim series 2
    Nov 2009
    hobart
    mate i fixed my 5l ute a shitload. water in the fuel tank does funny stuff sometimes. i replaced ignition module 200 reco, leads, plugs, coil and a couple of sensors and it went from shit to holy shit! but a low speed miss sounds like a poor contact somewhere. ya just gotta get out the multimeteer and check from bottom to top. also you should pull off your intake manifold and file out the ports a bit cos on mine there was so much extra metal that i got about 10 percent more area on each one. and it went stacks better after that. 2nd gear off the line and smoking both bags to 110 k. and 3rd to 140. lol. good luck mate mine pissed me off no end.
  1. vs 5 litre hard to start when warm
    By 96VSSS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-05-2012, 04:14 PM
  2. HSV VT 5 Litre vs Standard 5 Litre
    By Oken in forum General Discussion
    Last Post: 03-08-2009, 06:56 PM
  3. 6 litre or 5.7 litre conversion
    By kohan in forum LSx Development and Modification
    Last Post: 28-06-2009, 01:43 PM
  4. Warm Air VR
    By not_just_any_vr in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-07-2006, 09:32 PM
  5. Warm Air
    By Stretcher Bearer in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-02-2006, 10:16 PM
