Results 1 to 5 of 5
Thread: VR BUICK COIL PACK WIRES + and - which wires???
    H1GHROLLR's Avatar
    H1GHROLLR is offline CHEMICALLY SUPERCHARGED
    VX CLUBSPORT R8 LS1
    Feb 2009
    ROCKINGHAM,PERTH
    Exclamation VR BUICK COIL PACK WIRES + and - which wires???
    hey people i have a vr commodore buick V6 and im trying to work out which is the main
    positive+ and the main negative- out of all the wires that connect into the coil pack via the
    harness , does anyone know what colour/s etc ????
    {H1GHROLLR} CHEMICALLY SUPERCHARGED A.K.A NITROUS FED R8 CLUBBY and {HYPED UP} TWIN TURBO VX SS DAILY
    vs commodore
    Oct 2009
    Tamworth NSW
    This is for a VP.Im pretty sure they are similar..The main wiring that goes to/from to the DFI module which sits straight under the coil packs are.Red=the main 12v power feed.White/Violet=ECU.Black/Red=ECU.White=ECU.Tan/Black=ECU.Brown=Tacho.White/Black=crank angle sensor.Grey/Red=crank angle sensor.Blue/Yellow=crank angle sensor.Light blue/White =crank angle sensor.
    And I think the DFI module is earthed through its mounting where it bolts to the engine block.Theres no negative wire in the diagram,unless it earths through the ECU somewhere.
    H1GHROLLR's Avatar
    VX CLUBSPORT R8 LS1
    Feb 2009
    ROCKINGHAM,PERTH
    thanks for that info mate can anyone confirm where the main negative is for the coils
    H1GHROLLR's Avatar
    VX CLUBSPORT R8 LS1
    Feb 2009
    ROCKINGHAM,PERTH
    maybe delco wizzard will jump in on this convo
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    The VS wiring diagram indicates the DFI module earths thru it's mounting to the engine block as Brett suggested.
  1. Where to run the wires for a amp and sub in a vs?
    By vs_commy5506 in forum Car Audio
    Last Post: 25-07-2009, 06:23 PM
  2. What wires are these?
    By cypher967 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-09-2006, 10:51 AM
  3. Amp Wires?
    By todds_vt_2005 in forum Car Audio
    Last Post: 19-03-2006, 11:46 PM
  4. ignition coil wires for tach hookup
    By tgolds1 in forum Electrical Wiring / Questions
    Last Post: 29-09-2005, 08:06 PM
  5. wires?
    By silver_bullet in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-07-2005, 10:00 PM
