Results 1 to 9 of 9
Thread: Temp gauge reading to high.
    1998 HSV VT GTS 5.7 Stroker
    Mar 2010
    Tauranga NZ
    Default Temp gauge reading to high.
    As the title says,Open road driving it sits just under half.Around town sits just over half,Is this about right.seems pretty high to me.My old VN only moved off the first make.Water levels are ok.
    88GreenVN's Avatar
    88GreenVN is offline On sick leave
    88 Green VN Wagon 400,208kms
    Jun 2006
    Deep South - VN Country
    The VN's were very low reading gauge from all the VN's I've had.
    But over half way is a little high...
    and 2 Dangerous non ABS VN's
    sik_dose is offline Hybrids. Cars for fools.
    1986 VL Calais 5 Speed
    Feb 2010
    Have you belead your system? is their coolant or water in it? and in the thermo opening?
    Mar 2010
    Tauranga NZ
    Quote Originally Posted by sik_dose View Post
    Yeap.I've done all of that.
    VS commadore V6
    Mar 2007
    Sounds normal for a VS, actually better than mine and my cooling system is spot on.
    96 VS Acclaim Wagon w/VX clubby body kit
    Jan 2010
    Belmont, Perth, WA
    mine runs quite hot too and thru summer will get higher so i just run around with air cond on and it hardly moves off like quarter
    vs series 2
    Jan 2010
    Burleigh heads qld
    I know that when the vs first came out, customers were complaining about this, the fix was to replace the sensor with an aftermarket type sensor, all it did was make the reading on the gauge a little lower, i wouldnt be to worryed about this but in saying that keep a close eye on your coolant levels and check offen
    VS Exec Series II
    Mar 2005
    Just under 1/2 while driving is a little higher than my VS which sits on just over 1/4 at speed. The gauge will climb up to 3/4 though when the fan kicks in at traffic lights (if there long enough).
    I wouldn't worry though as long as the fan kicks in around the 3/4 mark and can bring the temp down while idling in traffic on hot days.
    As others have suggested, if the thermostat and radiator fins and coolant are in good condition with no air in the system then I really wouldn't get too worried.
    My last job was near the city centre so I added a thermo fan switch due to all the stop/start driving to give the tranny and engine an easier time of it but that's just my mechanical sympathy in action!
    fkford is offline Love The Beast!
    VS exec S2
    Mar 2009
    my VS used to do it. changed the temp sender and bang we have a winner. try the search option on this forum there is alot of threads on it with part numbers
    stop droolin
  1. oil temp/water temp gauge wiring
    By HUMBLZ in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 26-05-2011, 03:53 PM
  2. normal running temp for a VT 5L? and temp gauge..
    By mike49 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-08-2009, 11:57 PM
  3. VP Commodore / No Thermo without aircon - ECU Reading temp fine...
    By camstatic in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-02-2009, 01:23 PM
  4. Temp. gauge reading
    By vs_ute_89 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-09-2008, 08:26 AM
  5. Temperature Gauge: reading?
    By Morton in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-09-2007, 05:55 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
