Results 1 to 11 of 11
Thread: Checked codes on my 1994 VR commodore
    Vr Executive s2
    Jan 2010
    Default Checked codes on my 1994 VR commodore
    Hi all i have checked the codes on my vr commodore and come up with these codes in this sequence.
    12 - Code 12 - System Pass (OK)
    13- Code 13 - Oxygen Sensor (O2) - No Signal
    28 - Code 28 - Pressure Switch Assembly Short Circuit - Auto Transmission Code
    21 - Code 21 - Throttle Position Sensor (TPS) high voltage
    31 - Code 31 - Theft Deterrent Signal missing
    is it possible for anyone to give me advice on how to fix these problems or is it best i take it to a auto machanic.
    chrisdoesitbetter's Avatar
    chrisdoesitbetter is offline | → ³8°º™ ← |
    VR 3.8L
    May 2009
    13- Code 13 - Oxygen Sensor (O2) - No Signal get under your car and check the wiring from your o2 sensor, if you cant find anything try replacing it (cost about $100 from holden)
    21 - Code 21 - Throttle Position Sensor (TPS) high voltage replace the sensor, its at the back of the throttle body directly behind the butterfly
    Vr Executive s2
    Jan 2010
    does anyone know how to fix 28 - Code 28 - Pressure Switch Assembly Short Circuit - Auto Transmission Code.
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    Vr Executive s2
    Jan 2010
    yah i have its on the right level but im going to drain it and replace it when i get payed
    Kurtp's Avatar
    Kurtp is offline VR Buicks > You ;)
    VR Series 2 V6 Sedan
    Aug 2009
    Pakkey VIC
    The code 31 would be probably caused by a old key, not disabling the immobiliser, common problem. Have you had any trouble starting it?
    Vr Executive s2
    Jan 2010
    kurtp i got 1 key that works sometimes. the 2nd key i got works perfect. i noticed today one of the metal bars that gets the signal is broken so gotta get it fixed
    ty for replay and info
    Vr executive
    Apr 2010
    Hi
    I'm new to this site I have a 94 vr, I have just had a new key programed for my car
    the car was showing a 31 code,
    it started fine this morning I drove approx 30 mins stopped to drop off my daughter when I got back in the car wouldn't start, I tried it off and on for approx 30mins while waiting for racv and eventually it started fine, I cancelled racv drove to work when I was leaving work same thing happened
    any ideas would be greatly appreciated
    thanks Mandy
    vs commodore
    Oct 2009
    Tamworth NSW
    Vr executive
    Apr 2010
    Quote Originally Posted by Brett_jjj View Post
    Is it like nothing happens at all when the key is turned to start?
    Hi
    I spoke to my dad last night we took off the engine fuse for approx 20 seconds, put it back and the car started. Hopefully this has erased the memory, I didn't lock the car last night and this morning it started fine.
    I don't know if this will fix the problem I'm a bit to scared to lock the door, but i'll test it out tomorrow when i'm at home.
    Thanks
    vs commodore
    Oct 2009
    Tamworth NSW
    The metal tags around the ignition key hole,(the key reader) might not be touching the little metal contact on the keyfob properly.This will cause nothing to happen when turned to the start position.Check the metal tags around the keyhole,maybe carefully bend them out a tiny bit.
  1. My 1994 vr commodore
    By commodore crazy in forum VR - VS
    Last Post: 20-12-2010, 05:29 PM
  2. my 1994 VR Commodore BT1 :)
    By mike49 in forum VR - VS
    Last Post: 01-09-2010, 09:35 PM
  3. [QLD] 1994 VR Commodore $1,900
    By shaunzo101 in forum Vehicles For Sale
    Last Post: 07-02-2009, 06:45 PM
  4. [WA] 1994 VR commodore
    By caekmaster in forum Vehicles For Sale
    Last Post: 26-01-2009, 12:11 AM
  5. checked error codes now need help
    By muzza in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-09-2008, 08:45 PM
