Results 1 to 7 of 7
Thread: VS Walbro GSS-342 550HP fuel pump, yes or no?
    hsv91ss's Avatar
    hsv91ss is offline Holden4eva!
    VS Commodore SII
    Jun 2005
    Central Coast
    Default VS Walbro GSS-342 550HP fuel pump, yes or no?
    Hey guys
    My fuel pump went and I want to replace it with something reliable
    So I can get a Walbro GSS-342 550HP 255LPH for $132 or should I just buy the stranded replacement pump?
    I also wanted to know is it reliable has anyone got one and would it be suitable for me as the only mods I have is an exhaust and CAI I won't be touching cams etc until off my P plates, and don't want it too much heavier on fuel because of a pump
    Any help would be appreciated.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    I haven't fitted the pump you describe but I can assure you that the original factory unit is totally reliable is all you need - they are on Ebay (Delphi brand) now for well under $100.
    The bonus with fitting the standard unit is that you know it will fit!.
    Mar 2009
    i would stick with a genuine pump, you really dont need a bigger pump unless your going to build a crazy motor.
    Here is a link to a company that i have used many times, most the parts i have got from them have been genuine brand (delphi) and there delivery times are awesome!!
    Cyberspace Auto Parts - EFI and Engine Management Automotive Components
    Wagon_Wheel's Avatar
    Wagon_Wheel is offline Drop A Patch....
    Aug 2005
    Mt Martha, Vic
    Just stick to a standard pump dude, they will pump enough fuel for even mildly worked cars, Ive got the same Walbro pump in my VS, and ive had no troubles with it. But its not exactly standard, you will have to modify the sender unit to make it fit, its a bit fidly. Stick to something like a Bosch unit if you want something with a good name
    hsv91ss's Avatar
    VS Commodore SII
    Jun 2005
    Central Coast
    Thanks for the Info will stick to the stock pump as I wont be doing much to it in the coming months and a V8 will be going in once off the P plates as my uncle has a mildly worked 5 Liter and T5 sitting around doing nothing.
    Found a for $77 with shipping so will go for that.
    Thanks again.
    GTP 85's Avatar
    GTP 85 is offline 291 hp @ the wheels
    VS track car & VS SSenator
    Aug 2006
    Adelaide, near the bay
    i know i'm a bit late but fitting a walbro to the standard sender is a cinch. I just ditched the pulse dampener and hose clamped some fuel line in to fit snug. They are cheap as chips too, so why not if your keen? Beware of imitations tho... i've been had once
    Hit me up with some reputation points if i've helped you out! (Star in the bottom left!) Cheers!
    GT Performance RUF 231- NA 3.8L- 13.30 @ 103 Mph... So far... Cam, compression and revs! MY CAR>> http://forums.justcommodores.com.au/...tml#post471410
    Daily VR SS: http://forums.justcommodores.com.au/...ite-vr-ss.html
    hsv91ss's Avatar
    VS Commodore SII
    Jun 2005
    Central Coast
    yeah I was going to get the Walbro, however funding is a little low and I just want it back on the road.
  1. Walbro 500hp fuel pump issue!!! need help plz
    By BIG-EV in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-09-2009, 10:52 AM
  2. VS Fuel pump- Walbro Replacement?
    By Lazin in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-04-2007, 10:31 PM
  3. walbro 600hp pump + malpassi = 50psi pressure
    By tysons_2001 in forum V6 Development And Modification
    Last Post: 13-04-2007, 11:31 AM
  4. walbro fuel pump
    By daron in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-03-2007, 09:53 PM
  5. F.S Walbro Fuel Pump
    By VTSS350 in forum Parts And Other Items For Sale
    Last Post: 06-11-2005, 04:33 PM
Tags for this Thread
