Results 1 to 2 of 2
Thread: vr not starting
    VR Calais S2
    Feb 2008
    Tweed Heads
    Default vr not starting
    I've been having problems starting my calais over the last couple of weeks, but haven't actually driven the car since last week. All the ignition lights wrk but when I try and crank the motor there is no response. The remote central locking isn't working so I asked around and was told that the battery in the remote might be flat and that could be the cause, but after buying a new remote this morning i couldn't program the new remote because the security system wasn't reseting (the security LED wasn't flashing) after I jumped into the drivers seat and manually locked the door from the inside. I can't actually recall seeing the LED flashing when the problem started and I'm ust wondering if it is at all possible that a fault in the alarm system or immobiliser is the problem? Any help would be appreciated.
    Last edited by jt_vrcalais; 14-03-2010 at 05:24 PM. Reason: Needed to be more specific
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    You need to be more specific about the starting problems you are having if you expect any serious help.
  1. EFI VK not starting.
    By '88 VN Custom in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 11-09-2009, 10:20 PM
  2. starting
    By ianf in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-08-2009, 03:26 PM
  3. Vn Not Starting.
    By K1ND3R in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-03-2009, 09:18 PM
  4. HELP car not starting!
    By sebstenator in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-05-2008, 07:48 PM
  5. vn not starting
    By vn4play in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-11-2005, 05:30 PM
