Results 1 to 3 of 3
Thread: Ute Diff
    Kurtp's Avatar
    Kurtp is offline VR Buicks > You ;)
    VR Series 2 V6 Sedan
    Aug 2009
    Pakkey VIC
    Default Ute Diff
    Hi guys, i'm gonna replace the rear axle diff etc on my car, and have found a cheap one from a ute, will the ute one be the same as my sedan? The ute is a VS, my vr is a sedan.
    Mar 2009
    No there different, Ute diffs and wagon diffs are the same (minus the plate for bump stops but that doesn't matter)
    You cant put a ute or wagon diff in to a sedan, the mounting brackets for the shocks are different.
    The ute diff has a pin that the shocks slide on to then a nut to hold them on there, where as the sedan has a bracket the shock sits in with a bolt through it to hold the shock in place.
    Kurtp's Avatar
    Aug 2009
    Pakkey VIC
    Thanks for that westbad.
  1. Changing vx diff do you have to unbolt the whole rear end or just the diff unit
    By H1GHROLLR in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-11-2009, 06:35 PM
  2. whats the diff between the diff diffs?(wagon and sedan)
    By redrags in forum VL Holden Commodore (1986 - 1988)
    Last Post: 30-05-2009, 09:51 AM
  3. changing diff gears or full diff replace?
    By callum_88 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-05-2009, 06:59 PM
  4. diff making a noise / replacing diff
    By yipya in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-12-2008, 11:30 PM
  5. Putting in new diff oil and replacing diff gasket ?
    By gemini in forum VL Holden Commodore (1986 - 1988)
    Last Post: 07-10-2007, 05:22 PM
