Results 1 to 13 of 13
Thread: Stock VS + new springs = :S
    VS
    Mar 2009
    Default Stock VS + new springs = :S
    hey guys!
    i had a search around but couldnt find much, possibly because im so lazy
    just wondering what the lowest LEGAL king/pedders springs you can put on a stock as a rock VS sedan are in victoria
    thanks
    2005 VZ SV6
    Jun 2009
    Australian Crapital Territory
    Depends mate, on what size rims etc you have.
    Lowest legal limit is 100mm at the lowest point. You would be definately fine with superlows, although if you were running 15's, you should even be ok with ultra lows.
    VS
    Mar 2009
    as i said, stock everything, so wheel diameter hasnt changed from the hubbys
    2005 VZ SV6
    Jun 2009
    So yeah would definately be safe with superlows, although I have 19's and superlows and still way legal. You would probably be safe with ultra lows
    VS
    Mar 2009
    i really want to go ultra's but i want everything legal.. do you know how many millimetre's each spring takes off the ride height?
    2005 VZ SV6
    Jun 2009
    Umm Im now 100% but if you have a snoop around on the King Springs site it says there im pretty sure.
    I know that SL's take 50-60mm down, and I think UL's are 70-80mm?
    Mar 2009
    your going to be pushing it on ultra lows with stock rims.. i would stick with super lows if you want to stay legal
    Bagged/Walled WHII Statesman
    Feb 2010
    WA
    HamaTime™'s Avatar
    HamaTime™ is offline VIP Member
    97 - VS S
    Operation Tiger Champion! Marble Mayhem Champion! Spacerunner 2 Champion! Triathlon Champion!
    Feb 2008
    Front - Supers
    Rear - Ultras
    looks shmexy!
    Super Low's are legal, Ultra lows not usually.
    1997 VS II - S
    Stage II Auto: Pacemakers & 2.25 Hi Flo: VT Brakes: Lowered: Spaced & Insulated
    VS
    Mar 2009
    Quote Originally Posted by HamaTime View Post
    Front - Supers
    Rear - Ultras
    looks shmexy!
    exactly what i want!
    and yes IRS i believe
    found some nice fine print on the king springs website
    "Super Low springs lower vehicle approximately 10-20mm lower than normal Low Ultra Low a further 10-20mm again."
    original spec's on a VS say the ride height is 147mm (please correct me if i'm wrong)
    so the max ride drop should be 40mm which if just above legal :S
    but this seems not to be the case...
    VS
    Mar 2009
    HSV +6
    Mar 2006
    Mornington Peninsula
    I have a 93 VR Exec wagon, im assuming its live axel not IRS, i plan on chucking 17" or 18" rims on, whats the best height for it?
    Holden VS Series II 1997 Ute - 5 Speed Manual
    Aug 2008
    Quote Originally Posted by And_ROOS View Post
    Superlows all round probably.
  1. [VIC] Wtb: Vn stock springs
    By Noy in forum Swap / Wanted to Buy / Trade
    Last Post: 26-03-2009, 04:11 PM
  2. WTB: VN stock springs
    Last Post: 10-11-2008, 11:26 PM
  3. F/s Vs Stock Springs
    By biganf in forum Parts And Other Items For Sale
    Last Post: 27-02-2007, 09:19 PM
  4. Has anybody ever swapped stock springs with SS springs?
    By vzuterus in forum General Discussion
    Last Post: 01-06-2006, 02:20 AM
  5. Swapping stock springs for SS Springs
    Last Post: 25-03-2006, 11:00 AM
