Results 1 to 7 of 7
Thread: Quetion about replacing fuel pump on a VS
    96 VS Acclaim
    Mar 2010
    Default Quetion about replacing fuel pump on a VS
    Hey folks, first time poster and complete newbie to car motor modification/mechanics. I have a pretty foolish question but I thought it'd be best to ask and be safe rather than blow myself up.
    It has to do with replacing a fuel pump on a dual fuel VS acclaim. I know you have to release the pressure before doing anything but because I am on dual fuel I thought there may be an additional step before disconnecting the pump. Not much of a car whizz (but I have worked on a lot of 2-stroke motors so I'm not a complete mechanical noob) hence the stupid question.
    Okay you'll probably roll your eyes and tell me that after disconnecting the relay and running the engine till it cuts I'm fine - LPG or ULP it doesn't matter - right?
    Cheers folks!
    Mar 2009
    you do know your fuel tank should not be pressurized it has breather hoses... and the fuel pump is inside the tank its self.
    hsv91ss's Avatar
    hsv91ss is offline Holden4eva!
    VS Commodore SII
    Jun 2005
    Central Coast
    I am replacing mine tomorrow, lol I don't have to worry about pressure because it wont even start.
    Is simple though dual fuel or not, just remove the sender/pump assembly from the tank and replace
    but to answer your question Run it on ULP till it cuts as your not going to be touching any of the LPG setup.
    VS 5 Litre BT1
    Jul 2006
    VS l67 statesman
    Dec 2008
    My pump shit it self when I just put 73 liters of fuel in talk about a night mare to drain ! and laying in all of that fuel and trying to mop it up while replacing the pump I will never forget
    2000 VS Ute 5 Speed
    Oct 2008
    Western NSW
    Just replaced my fuel pump, its harder than you think, getting the actual pump out of the tank and putting it back in is a pain in the arse (be careful not to snap your fuel gauge rod), all the rest is pretty straight forward.
    savage1987's Avatar
    savage1987 is offline fail champion
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    Quote Originally Posted by westbad View Post
    DUDE!
    There is OFTEN pressure in the fuel lines when you are removing a fuel pump, I don't know why but it's there.
    deXtrous: start and run the car on PETROL, so it's running on PETROL (important) then go to the engine bay and pull the fuse marked 'fuel pump'
    This will still leave a bit of pressure in the lines, but not as much. Be careful not to spray fuel in your eyes, I've done this and it is not good. Take great care doing a fuel pump for the first time, do your fuel filter while you're at it.
    It is possible to do the job with tank still bolted up in place, but not adviseable for your first time. Remove the tank and do it that way, much easier to see what you're doing and it is a tricky job for a first timer.
    May as well replace your breather hoses while the tank is down too, if they are stuffed (most are)
    Try not to get any silt in your fuel tank, just go nice and slow and you'll be right
    WTB: mulberry VN interior parts
  1. Replacing a Fuel Pump
    By fekme in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-05-2012, 06:31 PM
  2. need help on replacing fuel pump
    By jaz_777 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 24-01-2010, 05:25 PM
  3. ok so im replacing my fuel pump on my vs ute!! plz help!
    By VS5spdV6uteowner in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-01-2009, 06:25 PM
  4. replacing the fuel pump
    By dusted in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-07-2006, 11:19 AM
  5. Replacing Vk Fuel Pump
    By kel479 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 22-04-2004, 09:40 AM
