Results 1 to 11 of 11
Thread: Gas good but not running on petrol
    2003 SII CV8 Monaro
    Feb 2004
    Perth, WA
    Default Gas good but not running on petrol
    Hi all
    Ok so my VS had a dual fuel setup installed a year or so ago and recently it no longer runs on petrol. I have to manually set it to gas each time and it does start and runs normally on gas once it's going. If I try to switch to petrol while running it coughs a few times then dies.
    Now a while ago it had a backfire, thought nothing of it however I discovered after a few days driving it had actually blown out half the air box meaning it was inhaling unfiltered air (sounded and ran normally at the time). Air box and filter replaced now of course.
    My random guess might be that the fuel injectors are clogged? Can anyone who knows these things better confirm or deny what might be causing it?
    2003 SII CV8 Monaro
    VY
    Oct 2009
    hoppers crossing
    hey i had a similar problem with my vy, i simply changed the injectors and the coil pack, gave it a nice rev and it was all good
    HamaTime™'s Avatar
    HamaTime™ is offline VIP Member
    97 - VS S
    Operation Tiger Champion! Marble Mayhem Champion! Spacerunner 2 Champion! Triathlon Champion!
    Feb 2008
    Yeah, try replacing your injectors, maybe coil pack as well...also check your MAF (Mass Airflow Meter) - which can be blown by backfiring.
    With a dual fuel car, if you run primarily on gas, make sure you run petrol at least once every 2 weeks, for at least 15 k's including a good rev to clean injectors and to keep the petrol system fresh.
    I run 2 tanks of gas to $20 of 95 or 98 Petrol...
    1997 VS II - S
    Stage II Auto: Pacemakers & 2.25 Hi Flo: VT Brakes: Lowered: Spaced & Insulated
    vs commodore
    Oct 2009
    Tamworth NSW
    If a gas/petrol vehicle is not run on petrol for a few minutes every couple of weeks the fuel pump can seize up through lack of use.Sometimes a good bang on the bottom of the fuel tank with a rubber mallet will fix em up and get it running again.Have seen this a few times before on duel fuel cars where gas has mainly been used and they havent switched to petrol regularly.When running on petrol you should be able to hear the fuel pump running,with the engine idling if you get under the rear of the car and get your head near the fuel tank and you should be easily able to hear the hummimg sound of the fuel pump running.Get someone to switch over the fuel and listen for the pump to run from the back of the car.Make sure the fuel filter is replaced often because they dry out when not being used (when running on gas)and when they dry out crud and scum develops in them.Ive cut a fair few old fuel filters in half and you should see what is in some of them.It makes you wonder how stuff like that can get into a fuel tank and even more unreal is how it gets through the pump and its strainer etc.You should use the fuel in the tank every few weeks,otherwise it goes stale which will make the car run crappy when switched to petrol.And driving around town with the petrol tank full just wastes fuel because of the extra weight.Around a quarter of a tank is fine to keep it at.
    sik_dose is offline Hybrids. Cars for fools.
    1986 VL Calais 5 Speed
    Feb 2010
    Mar 2009
    2003 SII CV8 Monaro
    Feb 2004
    Perth, WA
    Thanks for the responses. Now you mention it I can never hear the fuel pump priming (even when it did work) will get a mate to help me out and ill stick my head under to listen. Otherwise it looks like new injectors/clean injectors etc.
    sik_dose: I have a wagon with the 55L donut tank so 1 tank doesnt equal 1 tank but usually a fill up of 50L gas gets me about 300km of almost all city driving. 17L/100km it works out at usually
    2003 SII CV8 Monaro
    5.0 VS UTE S-PAC
    Mar 2010
    spark plugs and leads mate. the exact same thing happened to my vs. im running duel fuel also. just had them replaced last week, no problems at all.
    5.0 VS UTE S-PAC
    Mar 2010
    by the way, i also go t anew fuel pump as mine also shit itself, at 235,000kms
    VS 5.0 HDT spec 195i
    Jul 2009
    Wollongong
    strgas's Avatar
    strgas is offline GRA = REAL HP
    Oct 2009
    be sure the fuel pump hasn't been turned off when running on gas this can over heat the injectors when running with out petrol in the rail to remove excessive heat , fuel in the tank is good for about 3-4 months using petrol regularly is best advice aleast 30 liters a month is recommended , regular filter changes as per service recommendations .
  1. Vn running bad when low on petrol
    By KeaganKaotic in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-01-2010, 08:34 AM
  2. vk 308 dual fuel not running on petrol?
    By vk5ltrm in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 07-01-2010, 10:50 AM
  3. running funny on petrol
    By Adriianz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-07-2009, 02:43 PM
  4. Running out of Petrol
    By Sara Pax in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-07-2008, 10:49 AM
  5. Not running on petrol
    By roxy in forum VL Holden Commodore (1986 - 1988)
    Last Post: 25-07-2004, 08:49 PM
