Results 1 to 4 of 4
Thread: loud clicking in rear left wheel
    Jan 2008
    Default loud clicking in rear left wheel
    got a 95 vs commodore and the rear left wheel makes a loud clicking sound when accelerating and can be felt by people sitting in the back. jacked it up to check it out but couldnt see much then drove again and it didnt make sound but keeps coming back after a while. only happens when accelerating and stops when rolling and not accelerating. was thinking wheel bearing or cv joint had carked it but was told it could be as simple as a spring from the brakes had come loose. any ideas?
    Reaper's Avatar
    Reaper is offline Tells it like it is.
    E3 Senator Manual, VP SS
    Aug 2004
    Could be either of those things. Won't know for sure till you have a look.
    Reaper
    Reapers Black VP SS
    0-60 mph = 5.39 Sec, 2.30 60'
    Quote Originally Posted by skruba View Post
    practice makes perfect dude i was (still am) my bros guinea pig,he has been tattooing for near 2 years.
    vs commodore
    Oct 2009
    Tamworth NSW
    As above,have a look. Take the wheel off and check it all out.It could be a wheel bearing,brakes,tyre or if its IRS the CV joint,also check the suspension bushes.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Check that the wheel nuts have not been loose in the past and worn the holes in the rims out so the nuts don't clamp the wheel to the hub tightly enough.....this can cause your problem. You can easily check by inspecting the wheel nuts to see if they have been bottoming on the hub - they should bottom on the wheel rim shoulder.
  1. Rear wheel hub replacment, or bearings, loud hum noise when turning at 50+ km/ph
    By welchy92 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-03-2010, 06:25 PM
  2. loud nocking noise in front left wheel when turning.
    By macksvt in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-12-2009, 07:57 AM
  3. Rear Left wheel bearing gone
    By darekg in forum VY Holden Commodore (2002 - 2004)
    Last Post: 04-03-2009, 07:21 PM
  4. loud noise in left rear wheel
    By johnny b in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-01-2009, 07:43 PM
  5. shudder from left rear wheel
    By georgeonboost in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-04-2007, 07:24 PM
