Results 1 to 8 of 8
Thread: vr power steering
    VR STATESMAN
    Mar 2010
    Default vr power steering
    I have just replaced the power steering pump on my VR V6, which has gotten rid of the awful sound, the fluid is new and after a couple of short drives the steering is as heavy as lead with no improvement. Seems like the power steering not working at all. Plenty of fluid in reservoir and no sign of any leaks. Bled the fluid in pump change by going lock to lock. What have I forgotten to do? Its like driving a tractor... thanks
    VS Berlina 3.8
    Dec 2008
    VR STATESMAN
    Mar 2010
    Had the rack replaced four years ago - would it have to be done again already? Sorry, am a novice, learning as I go...
    94 VR Executive & 99 VT XU8
    Mar 2005
    Melb
    im in EXACTLY the same position (rack done about 2.5/3 years ago)
    interested to know how it turns out.
    94 VR V6 - No ABS & NO IRS... a true mans steed and a 99 VT XU8 for good measure.
    VR STATESMAN
    Mar 2010
    Just had the harmonic balancer replaced. Was cracked and now the problem is soled. Thanks!
    vn calais 5speed
    Sep 2009
    So you had the harmonic balancer replaced, it was cracked and not driving the belt? or?
    Its just i've got the same problem on a vr calais v6 series 2, bought the car with steering heavy as f***, the bloke i bought it from said he had replaced the pump and that didnt fix it so he's selling it, i bought it and took it for a couple drives and it was heavy steering then some days it would randomly go light. I then took it to a mechanic to have it looked at and he said something in the struts were loose, not sure exactly what, so he tightened what ever it was, and the power steering worked fine and was extremely light, after a couple days of driving the steering has gone heavy as again. when the engine is idling and i turn the steering wheel (With struggle) there is no rev change or any load put on the engine what so ever. is this similar to the problem you had? if so i may hav to look into gettin the harmonic balancer checked.
    VY Ex-cop
    Mar 2006
    The1's Avatar
    The1 is offline A Memcal a Day Keeps..
    VS V6 Berlina Auto Series 1
    Jan 2005
    Toowoomba QLD
    If the harmonic balancer was not spinning driving the belt then you'd be in far worse trouble than no power steering as you'd have no alternator and no water pump, soon enough flat battery or overheating engine.
    If it's not working and theres plenty of fluid and the pump is spinning freely and without noises then either the internal prop in the pump is not making enough pressure to drive the fluid or perhaps there is a blockage in the rack or somewhere in the lines or even a leak. If it's coming and going then sounds like one of these.
  1. Power versus non-power steering columns?
    By BaggedVL in forum VL Holden Commodore (1986 - 1988)
    Last Post: 27-10-2009, 06:19 AM
  2. Replies: 1
    Last Post: 09-11-2008, 09:18 AM
  3. VH Power Steering..Trade For Manual Steering
    By vasrox in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 30-10-2008, 12:23 PM
  4. oil line from power steering to steering rack
    By onmy6 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-12-2007, 10:08 AM
  5. VH Power Steering..Trade For Manual Steering
    By vasrox in forum Swap / Wanted to Buy / Trade
    Last Post: 28-01-2007, 02:29 PM
Tags for this Thread
