Results 1 to 15 of 15
Thread: Horn Problem
    2000 VS Ute 5 Speed
    Oct 2008
    Western NSW
    Default Horn Problem
    When i bought my VS 3 years ago, the horn did'nt work. I did'nt really care, but now i want it fixed because i wanted to honk the horn at a bloody terrible driver that was holding me up the other day and nearly ran me off the road, but the horn does'nt work, i had to use hand signals instead, i admit i do get a little road rage sometimes, haha.
    Now, i had a look at the horn wires under the car and they were not connected, so i connected them and the horn came on straight away, but it stayed on and would'nt stop. So thats obviously the problem that the previous owner had. I think the button inside the steering wheel might be stuck on or something. Is there any way to take the front cover off the steering wheel so i can check it out? Or, what else could be causing this problem.
    Cheers guys.
    TheForgotten's Avatar
    TheForgotten is offline only human......
    VR EXEC
    Dec 2005
    quarantine
    if it's a non-airbag wheel the front just pulls off, but the horn button is sealed inside. i'd go through everything else, wires, relay, horn module, see if it's a simple fix or not
    Quote Originally Posted by MY-42-VT
    if they didn't have that thing between there legs we'd laugh and throw rocks at them
    WTB VR/VS FACTORY HEADUNIT BRACKETS PM ME
    2000 VS Ute 5 Speed
    Oct 2008
    Western NSW
    Thanks mate, yeh i have checked everything else, and im confident its the horn button/s. I pulled the front of the wheel off, but i can't really do much from there can i? Im thinking i may just get a new wheel, going to auto pro tommorow, i might pick up one of the sports ones, they should just screw straight on should'nt they.
    Mar 2009
    2000 VS Ute 5 Speed
    Oct 2008
    Western NSW
    Quote Originally Posted by westbad View Post
    with your ute being a series 3 does it not have air bag steering wheel??
    No, mine does'nt have an airbag. Should it?
    Mar 2009
    no they were optional, just wondered if it did have, most late model's do.
    VY SS
    Jun 2006
    Albany
    so did you plug the horn back in when u had the steering wheel front off? if your wheel is like my old one there should be 4 wires connected to a plug where 2 wires go to each horn button, maybe try cutting the wires on one side to see if that fixes it that way you will atleast have one horn button that works
    Chirpstr's Avatar
    Chirpstr is offline A new project attack
    VR Berlina M5, VP M5
    Sep 2007
    2000 VS Ute 5 Speed
    Oct 2008
    Western NSW
    Quote Originally Posted by axemurderer101 View Post
    Great idea mate, but how will i know which one is the broken one. I don't want to cut the wrong one. Do they need to be cut or can i just disconnect them from the button?
    99 VT Sedan
    Feb 2010
    I had same problem in my vr
    Not knowing of just commodores than
    I just wired in a little push button on dash
    Past pink slip and rta inspectors
    VR EXEC
    Dec 2005
    quarantine
    checking everything visually doesn't mean it's ok. there are some things you can do to test each component of the circuit, testing for continuity etc, 'backyard mechanics' such as just touching the horn terminals together behind the steering wheel etc
    i've been caught out by visual checks more than once
    VR Commodore
    Apr 2009
    Quote Originally Posted by 11gothevt11 View Post
    Yeah smart move not only you wreck the dash but defeat the purpose of fixing the problem in the first place.
    99 VT Sedan
    Feb 2010
    At that time I just wanted a quick fix
    As it was due for a pink slip
    If i knew about just commodores at that time
    i would of sorced out a proper fix
    99 VT Sedan
    Feb 2010
    Default Sorry to change sudject Rta inspectors came to my house
    Sorry to go off the topic The only reson rta inspectors came to my house is
    When i got my pink slip done 2 years ago a rta inspector came to my house and went over it
    Just be wary to where you get your pink slip done
    The guy was dodgy who done pink slip
    I only saying this as i have never ever heard of rta inspectors coming to my house
  15. #15
    VS executive
    Apr 2010
    i have a woodgrain steering wheel on my 96 exec and the horn doesnt wanna work can anyone tell me what could be the problem maybe the connections at the back?? or fuse?? cheers guys
  1. Horn Problem
    By ianf in forum Electrical Wiring / Questions
    Last Post: 07-07-2008, 03:27 PM
  2. vent problem and horn problem
    By plasmid2 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-06-2008, 10:53 PM
  3. Horn problem
    By mclutterham in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-01-2007, 08:31 PM
  4. Horn problem in VP
    By richie_cky in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-07-2005, 07:56 PM
  5. VX horn problem
    By Harry V in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-07-2005, 09:36 PM
