Results 1 to 14 of 14
Thread: fe2 height?
    vn executive s2 v6
    Jun 2008
    Default fe2 height?
    hi, can anyone tell me the height a vs would be if it had fe2 springs fitted? from the centre of the wheel to the top of wheel arch. any help would be much apreciated
    Mar 2009
    i can tell you standard sedan rear springs on a live axle VR/VS commodore are 370mm and FE2 are 336mm if that helps any??
    vn executive s2 v6
    Jun 2008
    yea it does help, thanx. do you have fe2 springs on your car? does anyone else no the front height?
    Mar 2009
    yes i have the full FE2 suspension as mine is a BT1 SS so its IRS which are different height to the live axle springs
    Im trying to find the info on the fronts..
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    I switched to FE2 in my VS wagon.
    Front went down 5mm and rear went down 35mm.
    I suspect the original front springs were sagged.
    VS 5 Litre BT1
    Jul 2006
    I just measured mine - BT1 5 ltr with FE2 - and it is 350 mm from the middle of the centre cap to the bottom of the wheel arch above the wheel...if that makes sense.
    VP Executive R-spec
    Jan 2005
    It'll be the same height as an S or SS you should be able to see one in your local street to compare
    Commodore Omega
    Aug 2010
    Fairfield, Melbourne
    Can anybody confirm the height differences between the standard, FE2, Super low and Ultra low springs, I have a set of new FE2 springs off from an SV6, and looking lowering my VE omega with 18" wheels, and I really want to know is it worth to put the FE2 or I should go for a super or ultra low.
    thanks
    hsv91ss's Avatar
    hsv91ss is offline Holden4eva!
    VS Commodore SII
    Jun 2005
    Central Coast
    Fe2 or lows are approx 20-30mm lower and supers 40-50mm
    I went Fe2 and was happy with it for a while and then a couple of months later I switched to super lows. at first I though yeah the Fe2 looked way better then stock but every time I seen a Commodore on supers go past i thought that looks heaps better.
    I switched to Supers and shortened shocks and never looked back look better and doesn't get decked over every speed hump I come across.
    94 vr HSV gts 6speed 5.7stroker 215kw
    Jun 2009
    no where
    giddy,i have fe2 sport suspension,as \vs5litre/ said 350mm from centre of cap to to the middle of wheel arch,my car vr hsv 5.7strker.hope that helps.
    NORTI's Avatar
    NORTI is offline come get me
    VR Calais 5L, WM Statesman
    May 2004
    Im on my phone so cant see your location, but seeing as you are asking for eyebrow height, then Im guessing SA.
    I have FE2 in the VR, with 18's, these are legal for eyebrow, everything else has dropped me below legal (3 regency defects to prove it )
    keep in mind that if you have anything lower, it will also drop a bit more after it settles, seen a lot of people stung by this
    Commodore Omega
    Aug 2010
    im in victoria mate..I dont want to change my springs again and again, that why I need to find out which is better then I can go for that, thanks for sharing
    Commodore Omega
    Aug 2010
    Today called up some shops, lowest quoted is $400 with new king springs superlows, they also said if I supply the springs they can do it for $185, and If i dont need a new spring then they can compress the existing onces for $250, pedders quoted $720, tyre factory quoted $600 with new pedders springs.
    Now I need to decide king springs or Pedders? which is better to go considering the cost aswell, or compressing my FE2's or stock? also what is coilovers???
    Any advices..thanks
    justbad4you's Avatar
    justbad4you is offline IF YOR NOT A HOLDEN
    97 VT BERLINA/ 98 VS SIII MALOO (RED) LX SLR5000
    Sep 2005
    MELBOURNE S/E BAYSIDE
    is it the same on a 1998 maloo?
    Quote Originally Posted by greenfoam View Post
    if so ill go and have a look and post the height?
    We ALL HAVE 1 THING IN COMMON:THE RELENTLESS PURSUIT OF GRIP
  1. VZ height
    By Simon W in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 23-11-2008, 09:37 AM
  2. VX SS Height
    By Just_Ice in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-04-2006, 12:00 PM
  3. ride height on my VG
    By Boonz in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-03-2006, 07:00 PM
  4. Anyone know L67 height?
    By Natsnud in forum V6 Development And Modification
    Last Post: 07-10-2005, 02:02 PM
  5. height help!
    By FullySik in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-06-2004, 06:24 PM
