Results 1 to 4 of 4
Thread: Losing Coolant Rapidly
    Josheh's Avatar
    Josheh is offline Custom Used Title
    2001 Holden VX S-Pac
    Dec 2008
    South Australia, Adelaide
    Default Fixed :)
    Fixed, Was just the cap.
    VR Caprice
    Dec 2005
    Could be Head Gaskets. Have you got water on your dipstick. Top it up and go for a drive and park on concrete then before you move it again check under the car, use anti freeze or something as its coloured. It could be welsh plugs.
    vs commodore
    Oct 2009
    Tamworth NSW
    Get the cooling system pressure tested.This test is cheap to get done and is the only way to be sure the head and inlet manifold gaskets are ok.
    Josheh's Avatar
    Dec 2008
    Thanks NeilB, I will look into that and give it a try!
    Thanks Brett, My Mechanic is a good friend of mine, And I'm always getting services and checks done on my car, He has done 2 pressure checks now, And also one where the blue dye turns green if there's a problem.
    I've personally not been able to find the problem at all, It doesn't seem to be going on the ground at all, Seen nowhere, Can't even see it through the engine, We ordered a new Coolant Cap "Forgot it's real name" Just to make sure it's not that, It didn't seem to be holding pressure properly.
    Cars, Go so very well and then out of the blue a problem or two!
  1. Losing Coolant
    By Tom_1569 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-03-2009, 07:43 PM
  2. VR losing coolant??
    By gontix in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-01-2009, 07:50 PM
  3. VR losing coolant
    By robs_vr_ute in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-10-2008, 01:07 AM
  4. losing coolant
    By Panama in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-03-2008, 10:31 PM
  5. VS s2 slowly losing coolant
    By immortality in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-09-2006, 07:11 PM
