Hi.
I was just wondering if there is a difference between buick manual starter motors and t5 ecotec manual starter motors?
And is there a spacer or shim needed when fitting it to the engine block?
thanks
They are both the same, so long as they are a starter to suit T5
Hit me up with some reputation points if i've helped you out! (Star in the bottom left!) Cheers!
GT Performance RUF 231- NA 3.8L- 13.30 @ 103 Mph... So far... Cam, compression and revs! MY CAR>> http://forums.justcommodores.com.au/...tml#post471410
Daily VR SS: http://forums.justcommodores.com.au/...ite-vr-ss.html
Yes as said they're the same. Also your right about the shim/spacer.
thanks heaps guys.
does anyone know where to find a replacement shim?
Cant say that i have ever used this said shim?
and i had a VN manual and currently have a VS manual
