Results 1 to 7 of 7
Thread: Installing cruise control in a VR exec?
    nathanVY's Avatar
    nathanVY is offline need boost...
    03 VY Calais, 99 VT Equipe
    Dec 2009
    Geelong, VIC
    Default Installing cruise control in a VR exec?
    anyone know if this is easy/worth doing?
    i do sooo many long trips i swear im gonna have arthritis in my right foot if I keep going with out it.
    woteva's Avatar
    woteva is offline NEED 4 SPEED
    VRII V6 Auto Wagon
    Jul 2005
    Adelaide S.A.
    It's easy if you got all the parts.
    Check your local Commodore Wrecker, they may sell all the parts as a kit.
    http://woteva.tk/
    If it ain't broke... I can break it for you
    nathanVY's Avatar
    Dec 2009
    Geelong, VIC
    hmm ok shall do! are there any write ups on here? is there anymore info you can give me on the conversion?
    vs commodore
    Oct 2009
    Tamworth NSW
    You will need to find out if the wiring is already there in the loom and dash.Someone on here should be able to tell you if the wiring is already there.You have to add the stop light/cruise cancel switches to the brake pedal.(theres 2 of them,ones a backup for safety)You need to add bulbs to the cruise control dash lights and add the blinker switch that has the cruise switches on it ,and of course you will need the actual cruise control module plus the cable for under the bonnet.There is also a relay under the dash you will need to put in.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    I have a feeling the wiring may not be in a '94 VR exec....it is possible to put a patch harness in but it is a lot of trouble in my opinion. I fitted genuine cruise to mine but it had the harness already as it's a late VS. In your case I'd fit an aftermarket model - the AP50 is about $200 and works good - I've fitted 2 to cars and no probs.
    nathanVY's Avatar
    Dec 2009
    Geelong, VIC
    hmm not sure if I like the ap50 as much, looks like it has better features though. what does everyone else think? genuine or ap50?
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    I think you'll find they all have identical features....just different methods of turning them on/off etc - there is also an AP60 and other models as well if you don't like the look of the AP50.
  1. installing cruise control
    By Snotty_vx in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-08-2008, 04:51 PM
  2. installing cruise control help
    By hombsch in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-05-2008, 02:50 PM
  3. Installing Cruise Control...
    By 1991_Vn2nV in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-09-2007, 11:33 AM
  4. installing cruise control
    By slappa. in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-10-2006, 09:22 PM
  5. Installing cruise control
    By Hakka in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-02-2006, 10:02 AM
