Results 1 to 5 of 5
Thread: Quick question, upper control arms, urgent.
    Cammed mafless VS Calais 5-speed.
    Dec 2008
    Default Quick question, upper control arms, urgent.
    Which way do the rear upper control arms go, flat side out or flat side in?
    vs commodore
    Oct 2009
    Tamworth NSW
    I have non standard top control arms but in the gregorys manual it says install them with the lip facing outwards and the bolts must be installed with the heads facing the outside of the vehicle.The top control arm bolts tension up to 60 -75 Nm. You should get a gregorys manual if you want to do jobs like this.That way you know its installed exactly right and tensioned correctly.I wonder how many arms are put on backwards.Same with the bolts.
    Dec 2008
    vs commodore
    Oct 2009
    Tamworth NSW
    Dec 2008
    Thanks for the quick replies mate.
  1. Commodore Adjustable Upper Control Arms
    By Dasher in forum General Discussion
    Last Post: 01-02-2010, 11:29 AM
  2. Upper control arms on VN Diff aftermarket or factory?
    By Bz Kn33z in forum General Discussion
    Last Post: 05-03-2009, 06:02 AM
  3. upper control arms
    By beefcream in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-04-2007, 12:28 PM
  4. Upper trailing arms
    By hispeedvp in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-01-2007, 08:47 PM
  5. rear upper control arms / bushes
    By grimnir in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-10-2005, 10:08 AM
