Results 1 to 4 of 4
Thread: Fitting towbar on a VS
    VS
    Mar 2010
    Default Fitting towbar on a VS
    Hey guys
    I need a towbar so that I can use the folks' trailer. Wondering what the easiest way of getting one is.
    It's a VS with a fixed axle, not IRS.
    - The car is lowered down to legal limit. This will mean that the towball will be a little lower than otherwise. Will this be a problem? It also has no wiring.
    What's the easiest way to put a towbar on do the wiring? Should I go to the wreckers and just get the parts or do it myself? Or is the job a pain in the ass and its easier to just get the mechy to do it?
    What's a reasonable price to pay for a towbar kit? There are some on ebay for $110.
    vs commodore
    Oct 2009
    Tamworth NSW
    The wiring harness and plug for a tralier taps into the rear tail light wiring in the boot.It uses plugs the same as the cars and takes 5 seconds to connect up.My VS has a metal piece through the boot which is something to do with towing and body strength.Wreckers or Ebay,its up to you.Dont pay too much though,phone around.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    With the solid rear end, any towbar from VN to VS will fit but don't get the heavy duty one like I did - with my FE2 suspension it scrapes on the ground regularly....the one that's rated up to 1200KG sits higher and weighs less. For the plug you can either fit an external plug and wiring or get the flat lead and hang it out thru the bootlid when towing - this is really the best option as the plug is stored in the boot when not used. To wire it in you can use either the piggyback connectors or cut the leads and solder the joints.
    mischa's Avatar
    mischa is offline <- 245rwkw Holden V8
    VN V6 T5 - 355 VN GRP A REP T56
    Jun 2005
    Ashbury, NSW
    If your in syd ive got one on the VN i want to get rid of, including wiring but its missing the tounge.
    Quote Originally Posted by keza87 View Post
    Really who wouldn't want to give Jack a good smack in the back of the head.
    The Daily VN T5V6
    355 VN GRP A REP
LinkBacks (?)
  1. 22-02-2012, 08:28 AM
  1. [VY] fitting towbar on vy
    By aza03 in forum Holden Commodore How-To's
    Last Post: 19-06-2011, 10:21 PM
  2. VN Wagon towbar fitting
    By thespirit in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-06-2010, 05:24 AM
  3. [QLD] vr towbar
    By vr5speed in forum Swap / Wanted to Buy / Trade
    Last Post: 14-07-2009, 12:19 PM
  4. Help fitting towbar
    By SweetWagon in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-07-2006, 05:21 PM
  5. VX towbar, will a ute towbar fit a wagon???
    By Phrog in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-01-2006, 03:31 PM
