I have a vs calais and the storage compartments or whatever they are called? are way to small, I was wondering if these were easy to mod, I would like wider ones so there is more room! like room for drink bottles and melways and what not, just room so I can get my hand in there, because these are really tight! and I have used them for anything yet! let me know what I can do!
You might run into a few problems trying to make the back end wider, as there is a possibility it could foul on the the seat height adjuster of the fuel cap release.
Your best bet is to pick up another one or two from a wreckers and experiment with them. Fibreglass is a good materiel to use for something like this.
You could cut the side out - basically the carpeted bit....and then install some elastic webbing across the where the side was. Lots of other cars have this as standard and it allows you to fit larger sized containers plus it holds them steady so the don't slide around or tip over.
