Results 1 to 10 of 10
Thread: VT v8 into a vs
    despo's Avatar
    despo is offline V Fast S furious
    vs series one
    Jun 2009
    Default VT v8 into a vs
    was dreaming last night of future plans for my vs..when i get off my ps wanna do something to the motor as the curent motor is reaching high kms...
    was wondering wat motors will fit into the vs so i know wat options i have
    VS Berlina 3.8
    Dec 2008
    Any motor will fit into a VS if you have enough money and time.
    As for bolt in's, any EFI 5 litre or Ecotec depending on the K-frame and motor in your car now. As for your current motor, it can be reconditioned too.
    despo's Avatar
    vs series one
    Jun 2009
    okk just some1 told me i would be restricted to what i could uprgrade to in the vs as if was a light commodore compare to laster models so could use their motors
    VR Caprice
    Dec 2005
    The VT Motor has a roller Block and sequensial injection. But the motor would go you would be advised to use your current BCM with a VS V8 ECU. The engine wiring looms are the same but theres quite a bit of difference in the working and wiring of the BCMs and other electrics. If you go to anything larger than a 5.0L then you will need to get it engineered. Look for a donor car without major front end damage as then you can use everything.
    despo's Avatar
    vs series one
    Jun 2009
    thanks heaps man thought so bout it having to get engineered to fit it in...soz new to this wat does BCM stand for?
    Mar 2009
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    Quote Originally Posted by NeilB View Post
    I am not familiar with this term. Explain please?
    despo's Avatar
    vs series one
    Jun 2009
    VT V8 Calais
    Mar 2007
    O.k, so you know the pistons go up and down right? haha just joking, The holden 5 Litre uses pushrods to open and close the valves in the heads. These rods are pushed up and down by the cam, on the VT 5 Litre these had little wheels that reduced friction between the cam and the pushrods, hence the term roller.
    50LTRv8
    RX25SE's Avatar
    vsII acclaim wagon
    Jan 2009
    Thanks. To me that would be roller rockers!
