Results 1 to 11 of 11
Thread: Bouncy Suspension after Lowering VS
    VR Ute
    Dec 2009
    Default Bouncy Suspension after Lowering VS
    I just lowered my VS ute and after doing so the car has become extremelly bouncy, from what i can tell most of this is coming from the rear of the car, i had suspicions that a shock was on its way out prior to changing the springs so i changed both the rear shocks with new standard Monro shocks. This has not fixed the issue what so ever. the current height in the rear has the wheel arch about half way through the 17inch tyre if that makes any sense (i dont know if there lows or super lows etc)... My through is that it could be the springs are too low for the shocks but im not sure and dont want to spend any more money on further new shocks if possible... other then that im really stumped. If anyone knows how to fix this it would be greatly appreciated.
    VS Commodore Ute
    Nov 2009
    VR Ute
    Dec 2009
    No not hard the exact opposite, its feels as if its going to slam through the road.
    woteva's Avatar
    woteva is offline NEED 4 SPEED
    VRII V6 Auto Wagon
    Jul 2005
    Adelaide S.A.
    Shockers bottoming out ??
    Hitting the bump stops ??
    http://woteva.tk/
    If it ain't broke... I can break it for you
    Holden VS Series II 1997 Ute - 5 Speed Manual
    Aug 2008
    Quote Originally Posted by woteva View Post
    AHA, even better riding on the bumpstops :P
    VR Ute
    Dec 2009
    No mate its not on the bump stops its just as if the shocks had NOTHING left in them, but there brand new and were hard as a rock to push in with your hand.
    VS Berlina 3.8
    Dec 2008
    Quote Originally Posted by shadowmaster View Post
    What kind of springs did you use? You really should use shortened shocks if you go lower than lows or fe2.
    hsv91ss's Avatar
    hsv91ss is offline Holden4eva!
    VS Commodore SII
    Jun 2005
    Central Coast
    Brand will make a difference, I had pedder lows and it was doing the same thing, pedders called it spring slap and repaired it by threading garden house over the coil springs so when it bounced it would hit the house and not bottom out, since then changed to king springs and never a problem.
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Priming the shock before they are fitted will usually stop this. Try unbolting the bottom mount and pushing the shock up until it stops, let it come back all the way out and push it up again. This primes the oil in the shock and moves the air back up to the very top where it should be.
    Visit my Facebook page
    2000 VS Ute 5 Speed
    Oct 2008
    Western NSW
    Its sounds like you are on super lows mate. I just put some used King "Lows" in my VS Ute and i also get a little bounce coming from the rear. I figured that because it is a ute it has hardly any weight over the back, as soon as i put my motorbike on the back, no more bounce. Apart from the little bounce, it is comfortable to drive. Since mine are only lows, i have no trouble with hitting or riding on the bumpstops. It might just be a ute thing. Not_an_abba_fan has made a good suggestion too, that makes sence.
    Quote Originally Posted by peckzz View Post
    also with this fuel thing, i had a old magna 4 cylinder 2.6 litre, and it wouldnt pull a burnout unless it was running 98 premium, so explain that 1?
    2000 VS Ute 5 Speed
    Oct 2008
    Western NSW
    Quote Originally Posted by VS-S-PACK-UTE View Post
    bouncy as in really hard? and jolty? if so that'd b the norm for a lowered ute lol.
    Thats not normal. I can see why yours would be very hard/jolty mate. Your on ultra lows with standard shocks and no bumpstops left. lol
  1. Lowering FE1.5 suspension.
    By SVZDavo in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 15-09-2009, 07:11 PM
  2. front strut all bouncy all of a sudden
    By georgeonboost in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-05-2009, 01:14 AM
  3. Suspension Lowering
    By hrforever in forum VY Holden Commodore (2002 - 2004)
    Last Post: 26-01-2009, 10:16 AM
  4. Lowering of suspension
    By coroman in forum VY Holden Commodore (2002 - 2004)
    Last Post: 26-07-2006, 06:13 PM
  5. Lowering/sports Suspension
    By EX_FORD_BOY in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-04-2004, 08:58 AM
